Quote:
Originally Posted by IMXCITD
I have a set of 305/35/18's on some rear wheels...can I run 335/30/18 instead? What is the difference?
Thanks for your help!
Plug in your #'s in this Tire Size Calculator:
http://www.miata.net/garage/tirecalc.html
You'll see what mixermike is talking about. It looks like the new tires would be 1/2 inch less in diameter, resulting in a few more revs per mile.
However, I don't think that is enough difference to bother your ABS or Active Handling. As you can see in the calculator results, your speedometer will be a little off.
According to the info on Tire Rack's website you should be running that 335/30-18 on a 11.5 to 12.5 inch wide wheel:
http://www.tirerack.com/tires/Spec.j...e1=yes&place=0
So....make sure your wheels are wide enough to take the new tires.
Bob
Forum member formerly known as "beezeye"
