10-04-2007, 05:54 PM
Junior Member
10% off Toyo Proxes R888
10-05-2007, 05:57 PM
CF Senior Member
What is a realistic life span for these tires if i use these for street?
10-05-2007, 05:59 PM
Junior Member
Quote:
Originally Posted by
vr6aaron
Depends on your driving style, but i would say anywhere from 2-5K miles. I would expect the wear to be around the same as a pair of drag radials. They talk about tread wear in the video review.
03-15-2008, 09:36 AM
CF Senior Member
TD4L
10% off Toyo Proxes R888.
coupon code: r888
Dave
www.TD4L.com
Dave, I have two line item in my basket, 1st line has 2 front tires, 2nd line has 2 rear tire, I then enter the coupon code, I only got 5% discount, not 10%. Have I done anything wrong?
03-15-2008, 11:35 AM
CF Senior Member
Got mine with the discount. Still need to mount them. And then the snow needs to stop.
Only 27 more days until the first autocross of the season here. Can't wait to get them hot. Even in my 50-deg F basement, they are pretty sticky.
03-15-2008, 12:23 PM
CF Senior Member
naschmitz
Did you get 10% discount, and when was it?
03-15-2008, 12:37 PM
CF Senior Member
YeeeeeHaw
Placed my order on 13-Feb and got the 10% discount. I think I found the "R888" promo code from some Oct-2007 posts at another forum.
03-18-2008, 02:35 PM
CF Senior Member
I ordered mine on 3/3 and only got 5%. I just called Dave and he said they changed it to 5% a few weeks back. Naschmitz, you must have been one of the last few to get the 10% discount.
Even with only 5%, it was still a better deal than I could find anywhere else on short notice.
03-18-2008, 02:42 PM
Junior Member
Sorry for the confusion guys. We had to reduce the discount a few weeks ago because of a cost increase. The R888 and PXR1R codes are now 5% off.
Dave
www.TD4L.com
03-19-2008, 10:31 AM
CF Senior Member
TD4L
Dave
www.TD4L.com
You should delete the thread or, change the title or put that up front on the first post.
That is pretty easy to do with the "edit" feature
03-20-2008, 07:56 AM
CF Senior Member
rbl
Title is somewhat 'misleading'. Of course, I suppose he will get someone that does not read the fine print......
__________________
Airport bum, Track bum, regular user of go-jo hand degreaser. LT4 - 372HP/355Torque, LS6 450HP/373 Torque.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
