Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-01-2007, 10:32 PM   #1
BandDirector
CF Member
Default Dumb C6 Lug Nut Question...
I'm in the process of putting C6 rims on my '98 Z28. I've got the rear spacers to make the 19x10 rears fit and I've got 255/35/18 front tires and 275/30/19 rear tires to work with my stock F-Body tire heights, so I only have one thing left to get and that's the lug nuts.
I have to admit that I've never looked at a C6 close enough to figure this out, so I'm going to have to ask a dumb question. (However, I did try the search feature).
Does the C6 use open ended lugs with chrome lug nut covers, or does it use closed ended chrome lugs and NO lug nut covers? I tried placing a set of my lug nut covers on the C6 rims and they seem to stick out too far, so that's what made me think that maybe chevy either went with a shorter lug nut than my F-Body, or they just did away with the covers all together on the C6.
Thanks in adavance!
__________________
www.banddirector.cz28.com
1998 Camaro Z28: LS6 Swap...and MUCH more! 385 RWHP
BandDirector is offline   Reply With Quote
Old 10-01-2007, 10:52 PM   #2
codysdad
CF Senior Member
codysdad's Avatar
Default No cover on the C-6
just closed end chrome nuts
codysdad is offline   Reply With Quote
Old 10-01-2007, 11:01 PM   #3
BandDirector
CF Member
Thanks!
Old 10-01-2007, 11:15 PM   #4
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Hmmm.....Actually the OE C6 lug nuts have a sheet metal cover.
I replaced mine with these:
That's a solid McGard 64002.
You can see it at:
http://mcgard.com/search/default.asp...vID=1&NavID=11
The stock C6 lug nut "looks" just like that McGard above, but the stock lug nut actually has the sheet metal covering over the steel lug inside.
Bob
Edited: I came back here after thinking about what you were asking, and I think I misunderstood. I don't know anything about the F-body wheels, so I can't quite figure out what "covers" you're talking about.
On the F-body is there some piece that you have to take off of the lug nut before getting your socket on it? It sounds like there is, from your question. If that's the case, then the C6 is entirely different. Even though the OE lug nut has a sheet metal cosmetic cover on it, it doesn't come off - it's molded around the steel lug nut and permanently stays on there.
So.....The C6 doesn't have any cover that you take off before you start wrenching on the lug nut.
BEZ06 is offline   Reply With Quote
Old 10-02-2007, 10:33 PM   #5
BandDirector
CF Member
Quote:
Yes, the F-Body has lug nuts and then plastic lug nut covers that screw on top of the actual lugs. When I tried them with the C6 rims, the "lugs" seemed to stick out about an extra 1/2" above the rim and it looked a little odd.
However, the lug nut you just posted is what I'm looking for, thanks!
Reload this Page Dumb C6 Lug Nut Question...
Tags
c6, corvette, lug, nut, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
