Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2001, 11:15 PM   #1
JAKE
CF Senior Member
JAKE's Avatar
Default 17" Wheels for a 1985 Vette
Hi all.
A buddy of mine who doesn't have internet access (if you can believe that in this day and age) asked that I post asking if there is a stock 17" wheel - 9.5" wide, that will fit his 85 Vette without using adapters. Or if there is an aftermarket 17"x 9.5 wheel that he can use without adapters.
As a fall back position, he's like to know if anyone in the Dallas, TX area can chrome his stockers.
I told him I'd get back to him when I got the info he wants.
Thanks to all.
Jake
JAKE is offline   Reply With Quote
Old 11-06-2001, 09:55 AM   #2
59er
CF Senior Member
59er's Avatar
Default Re: 17" Wheels for a 1985 Vette (JAKE)
Jake,
For that size he will have to use adaptors if he wants to use stock Vette 17's but most of the major aftermarket suppliers will be able to supply the 17's in the correct offset but you will probably need to determine the offset as a lot of those guys just can't be bothered to check it out and if they haven't got a listing then it's usually too hard.
If he's got 9.5" now, then measure the offset of those, but If he's got 8.5's he'll have to add the extra inch to either the outer or part outer and part inner.
If he's going to add some to the inner then he'll have to account for clearance of all components near the inner edge of the rim and he'll have to consider this at all points of the suspension travel.
I had an 85 before my current ride and I just had the old 16's polished and they looked great.
Your buddy should also consider the loss of ride comfort as there is a noticable difference between 16's and 17's.
Hope this helps.
Mark.
59er is offline   Reply With Quote
Old 11-09-2001, 08:54 PM   #3
gilbybarr
CF Senior Member
gilbybarr's Avatar
Look at AFS ZR1 wheels....17", 9.5 inch. They make the correct offset
for the 84-87 C4's. They have a tire wheel package that is reasonable and
the quality is top notch in my experience. Made my 87 have a whole new personality!
gilbybarr is offline   Reply With Quote
Reload this Page 17" Wheels for a 1985 Vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
my history is a little rusy, can you help!?! MattS4313 C4 General Discussion 12 01-23-2002 10:52 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
