Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2001, 07:35 PM   #1
Bill79
CF Senior Member
Default 79 and BFG TA 255/60/15
I replaced the rear spring and now the rear end sits higher and my 235/60/15 look way to small and do not look right will the BFG TA 255/60/15 fit ?
Thanks to All
Bill79 is offline   Reply With Quote
Old 11-06-2001, 11:11 AM   #2
1LE
CF Senior Member
1LE's Avatar
Default Re: 79 and BFG TA 255/60/15 (Bill79)
Yes, I have the 255-60-15's front and rear, no problems with rubbing.
1LE is offline   Reply With Quote
Old 11-09-2001, 06:13 PM   #3
Rockn-Roll
CF Senior Member
Rockn-Roll's Avatar
Be sure you inspect your parking brake bracket at the rear control arm for rubbing onto the inside of the tire. Mine was rubbing bad, so I took a grinding stone on my drill and ground it down about 1/4". I can see some marks where it touches the tire, but did not cut it up bad enough to weaken the tire. I was running Comp T/A R1's however and their section width is smaller than the cheaper BFG Radial T/A's...just take a look to make sure, or put some paint on the bracket then mount wheel and spin it and check for transfer of paint to tire.
Rockn-Roll is offline   Reply With Quote
Old 11-21-2001, 02:43 AM   #4
flynhi
CF Senior Member
Default Re: 79 and BFG TA 255/60/15 (Rockn-Roll)
To insure clearance on the parking brake bracket, it must be relocated to the top of the trailing arm. Easy to do.
Clearance when going straight does not insure clearance under hard cornering.
If you're running a VB rear spring, check clearance here also.
flynhi is online now   Reply With Quote
Old 11-23-2001, 01:29 PM   #5
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
The 255/60 was an optional tire from the factory and I think standard with the L82/4-speed and gymkhana suspension. As mentioned, watch for clearance at the parking brake bracket.
Also, if you install 255's in the front, you may have to do minor trimming at the lower rear portion of the front fenderwells. The outside edge of the tire may rub on the fender lip. There were some clearance problems that were handled by trimming right on the assembly line when the alloy wheels and 255 tires were installed.
c4cruiser is offline   Reply With Quote
Old 12-10-2001, 04:50 PM   #6
VetteBoy1979
CF Senior Member
CI 3-4-8 Veteran
St. Jude Donor '07-'09
VetteBoy1979's Avatar
Send a message via AIM to VetteBoy1979
I have Goodyear STs all the way around, 255/60/15. They were a factory option. There are no rubbing issues at all with mine. I also ran the 255/60/15 R1s on mine for auto-xing with no problems, except for cracking the frame :cry
VetteBoy1979 is offline   Reply With Quote
Reload this Page 79 and BFG TA 255/60/15
Tags
15, 255, 2556015, 60, bfg, ta
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tire size question... BlackRocket C3 Tech/Performance 21 09-03-2005 09:01 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
