Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-08-2007, 02:03 PM   #1
Rconce01
CF Senior Member
Rconce01's Avatar
Send a message via AIM to Rconce01 Send a message via MSN to Rconce01 Send a message via Yahoo to Rconce01
Default Tire Rim Offset
Guys on all stock C5’s the rear tires especially look a bit whimpy since they are not really flush with the rear quarter panels. Does anyone have a way to get those tires/rims to read kinda like the zo6 where the tire is practically flush with the edge of the quarter panel. I want to keep the same rims and tires. Is there a spacer available to achive this without having to change all the studs?
Rconce01 is offline   Reply With Quote
Old 08-08-2007, 03:54 PM   #2
WELEPRO
CF Senior Member
WELEPRO's Avatar
Send a message via AIM to WELEPRO Send a message via Yahoo to WELEPRO
There are companies that build spacers that go between the wheel and hub. The largest I've seen is 1/4 inch, which may not be enough to give you the look you want. Also, by putting something between the wheel and hub, you won't be able to put the lugnuts on as far, and that can be a safety concern. Some companies, like mine, won't allow the use of spacers in there stores.
The best way to fix your problem would be to go with a wider tire, or different wheel & tire combo.
Hope this helps!
-Erik
WELEPRO is offline   Reply With Quote
Reload this Page Tire Rim Offset
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
pics of widest rear rim and tire without tubbing??? robsvette C5 Tech 12 07-15-2003 01:21 AM
LA - OC - SFV area Tire Shop Recommendation cmuhlstein Southern California 10 06-20-2003 08:54 PM
C2 Performance tire size Gordonm C1 & C2 Corvettes 14 01-02-2003 09:52 AM
Largest rim/tires under 63-67 with offset rear, rim offsets front/rear? TCracingCA C1 & C2 Corvettes 23 09-30-2002 12:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
