Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2001, 12:39 PM   #1
abraham
CF Senior Member
Default kinesis wheels
How can I find out some prices on these. They wont return my emails and the tire rack doesent carry them.
abraham is offline   Reply With Quote
Old 11-03-2001, 08:37 PM   #2
93Polo
CF Senior Member
CI 3-4-5-9 Veteran
93Polo's Avatar
Send a message via AIM to 93Polo
Default Re: kinesis wheels (abraham)
Find David Farmer aka y2khardtop usually found over in the racing sedtion. http://forums.corvetteforum.com/zero...rofile&id=3130
93Polo is offline   Reply With Quote
Old 11-05-2001, 02:59 PM   #3
C4396roadster
CF Senior Member
C4396roadster's Avatar
Send a message via AIM to C4396roadster Send a message via Yahoo to C4396roadster
lets just say if it were me and I am going to spend big$ on your product and get no response move on to the next vendor cause your money is green and a good product vendor who appreciates your integrity by wanting product info will recognize this! every response should be handled with utter urgency but maybe thats just me!
C4396roadster is offline   Reply With Quote
Old 11-07-2001, 03:32 AM   #4
jgunn
CF Senior Member
I think they were at SEMA last week.
They are good guys with a top rate product.
I have a set I use for racing -- I take the wheels there for resizing (I am always changing my mind as to what type of tires I will run) and they get it done the next day.
Call and ask for Allen.
jgunn is offline   Reply With Quote
Old 11-07-2001, 11:05 AM   #5
bhays
CF Senior Member
bhays's Avatar
Send a message via AIM to bhays
Default Re: kinesis wheels (jgunn)
Ok, stupid question alert. I am trying to learn. What is resizing? You mean widening?
bhays is offline   Reply With Quote
Old 11-07-2001, 12:58 PM   #6
jgunn
CF Senior Member
Default Re: kinesis wheels (bhays)
yes,
Changing a rim half to go wider or change the offset.
James
Old 11-07-2001, 07:50 PM   #7
93Polo
CF Senior Member
CI 3-4-5-9 Veteran
93Polo's Avatar
JGunn what kind of wheels and model are you running? awesome pic. Looks like some fat rubber.
I have had great luck with Forgeline customer service. Just had an outer wheel half replaced. http://www.forgeline.com/ I've worked with Mark. When I sent the wheel up, he asked "What the #%*@ happened looks like you took a can opener to it? :eek: They look brand new now.
Lamar
Old 11-07-2001, 07:58 PM   #8
jgunn
CF Senior Member
Default Re: kinesis wheels (93Polo)
Kinesis K28
Currently 18X10 front and 18X12 rear.
I am going to try 18X11.5 in the front this weekend.
James
Old 11-07-2001, 09:46 PM   #9
korvetkeith
CF Senior Member
korvetkeith's Avatar
Send a message via AIM to korvetkeith
Dear santa.......
korvetkeith is offline   Reply With Quote
Old 11-08-2001, 03:49 AM   #10
4DCYKEY
CF Senior Member
4DCYKEY's Avatar
jgunn,
What size tires are you running on those rims? Have you had the car tubbed? I thought that the most one could get on the back was 11.5 inches...
Herb
4DCYKEY is offline   Reply With Quote
Old 11-08-2001, 01:32 PM   #11
jgunn
CF Senior Member
Default Re: kinesis wheels (4DCYKEY)
The front wheels are 18X10 which fit perfectly. No rubbing, etc. The best tire for that wheel is probably the 285/30/18. In the back I was running an 18X11 which, again, fit perfectly for street use. However, I decided to have it made into a twelve by changing the outer rim half for one 1 inch wider. So, now the rear is an 18X12. The rear sticks out from the fender about 1/2". Also, you need to keep enough ride height in the car to prevent it from hitting the fender lip. That means you need to see about one thread on the rear ride height adjustments.
The fact that the rear sticks out a little does not bother me for track use. On the street I would probably go ahead and tub it and add the inch on the inside. You could probably run a 13" if you could take 2" out of the inner fender by tubbing (pretty sure you can). You would also be able to lower the rear more (although I do not think that helps the cars handling -- you want some rake in the car).
The wheels are Kinesis. They are in Vista, CA, which is near my home so I can try things quite easily! Talk to Allen. They are very accommodating and produce a wheel that is second to none (including HRE,etc.). I know Fikse, HRE, etc. are a pain to get to change wheel widths or repair wheels.
I am actually trying an 18X11.5 in the front this weekend at an autocross. There are clearance issues on the A-arms at high steering angles, I want to see if I get to those angles or not.
Hope this helps,
James
Old 11-09-2001, 02:48 PM   #12
4DCYKEY
CF Senior Member
4DCYKEY's Avatar
James,
Thanx for the response...what size tires are you running on the back? Good luck with your experiments...
Herb
Old 11-09-2001, 02:59 PM   #13
jgunn
CF Senior Member
18X25.5.X12 Goodyear Slicks. Also could run a 335/30/18 in Hoosier, etc.
james
Old 11-09-2001, 06:42 PM   #14
93Polo
CF Senior Member
CI 3-4-5-9 Veteran
93Polo's Avatar
James,
Looks like an awesome setup. 18x12 is huge under a Corvette. A local is running Kinesis and loves them.
I have had great luck with Forgeline replacing wheels halfs, and polishing out curb rash. The only wheels I would consider buying are Forgeline, Kinesis, and CCWs.
Lamar
Old 11-10-2001, 02:08 PM   #15
abraham
CF Senior Member
Default Re: kinesis wheels (C4396roadster)
Just want to make a correction and say that Kinesis did respond to my email promptly but the mail got kicked back. Their prices are competitive and they will respond to anyone looking for prices or other info asap.
Reload this Page kinesis wheels
Tags
corvette, kinesis, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Kinesis Wheels for the C6. Alex Levy C6 Corvette General Discussion 11 03-14-2005 08:08 PM
KINESIS WHEELS FOR SALE !!! 01ZEE06 C5 Parts for Sale/Wanted 11 10-23-2003 03:14 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
