Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2001, 06:36 PM   #1
Hellraiser
CF Senior Member
Default EXSESSIVE tire noise. What gives?
Hey guys,
I just mouned on my 2001 C5 a set of used EMTs taken out of another 2001 C5. Well, I don't know if it's the tires or something else, but they are VERY noisy! The noise starts at about 15 miles/h and gets progressively worse! I had the tires checked and everything seems fine. Checked the bearing too, just fine. The tires have been perfectly balanced with stick-on weights. The job is superb. So, what gives?
I know that EMTs are not the quitest of the tires, but we are talking out-of-this-world noisy. What could be wrong? This is the first time I have change the tires on my car.
Any clues?
Thanks,
Andrew
Hellraiser is offline   Reply With Quote
Old 11-02-2001, 08:51 PM   #2
vette-crazy
CF Senior Member
Default Re: EXSESSIVE tire noise. What gives? (Hellraiser)
Hey Andrew! I got rid of my run flats and the noise went away. Until a month ago I ran the Nittos. They are inexpensive and grip like you would not believe. Much better than my Michellin Pilots. Get you a set of Nittos and get a 12vdc tire pump from sears. It even fits in your small well in the rear. Your car will ride as good as an STS Cadillac.
vette-crazy is offline   Reply With Quote
Old 11-02-2001, 10:28 PM   #3
Guest
Default Re: EXSESSIVE tire noise. What gives? (vette-crazy)
I was told by a Goodyear dealer due to the aggressive tread pattern the noise increases as the tire wears.I had a set of run flats on my 95 it was so noisy I took it to a G.M.dealer to have the rear end checked.He said all the noise was in the tires.Changed to a set of Goodyear Eagle Ultras and it was like riding in a different car.They are really noisy if they start to scallop.That is get a wavy feeling to the tread area when you run your hand over it. Chuck
Reload this Page EXSESSIVE tire noise. What gives?
Tags
2001, c6, ccorvette, corvette, noise, tire, z06, zo6, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
