Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Old 07-28-2007, 08:31 AM   #1
ryoder
CF Senior Member
Default Tirerack tread depth article
Tirerack put out an article about tread depth and safety in wet conditions.
I really believe them on this one. I don't let my wife's or my car ever get below 4/32.
I did a 360 at 70mph one time in my Camaro due to low tread depth on a just rained on highway. I wasn't braking or turning when the spin occurred either.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=85&
ryoder is offline   Reply With Quote
Old 07-30-2007, 09:45 AM   #2
Luke@tirerack
Platinum Supporting Vendor
thanks for noticing
Luke@tirerack is offline   Reply With Quote
Old 07-31-2007, 11:03 AM   #3
ctgene
CF Senior Member
ctgene's Avatar
Interesting article, thanks for the post...I had a car hydroplane on me once and did the 360 thing and luckily no one was near me except the guard rail which saved me from who knows what...
ctgene is offline   Reply With Quote
Old 08-02-2007, 09:46 AM   #4
EHS
CF Senior Member
EHS's Avatar
While tread depth and design has some influence in hydroplaning, the critical factor is not tread depth, but the speed at which you are driving in the rain (as you found out).
NASA (among others) has done a wealth of research, and it doesn't matter how deep your tread is, if you are driving to fast. Anything more than 57 mph in your Corvette, and you are asking for trouble.
Here's why:
http://howthingswork.virginia.edu/page1.php?QNum=1342
"...a NASA study showing that there is a minimum speed at which a tire will begin to hydroplane and that that speed depends on the square root of the tire pressure. Higher tire pressure tends to expel the water layer and prevent hydroplaning, while lower tire pressure allows the water layer to remain in place when the vehicle is traveling fast enough.. a large truck tire is typically inflated to 100 PSI and resists hydroplaning at speed of up to about 100 mph. But a passenger car tire has a much lower pressure of about 32 PSI and can hydroplane at speeds somewhat under 60 mph. That's why you have to be careful driving on waterlogged pavement at highway speeds and why highway builders carefully slope their surfaces to shed rain water quickly."
Two more links, one with a table to make the math easier:
http://oea.larc.nasa.gov/PAIS/Groove.html
and
http://www.mountainflying.com/hydroplane.htm
__________________
EHS is offline   Reply With Quote
Old 08-03-2007, 06:39 PM   #5
ryoder
CF Senior Member
That sucks.
Looks like I'll be running my runflats at 100psi from now on.
Old 08-04-2007, 06:33 PM   #6
UstaB-GS549
CF Senior Member
UstaB-GS549's Avatar
That sucks.
I'm going to run my race tires at 1,000 psi in the rain.
UstaB-GS549 is offline   Reply With Quote
Old 08-07-2007, 06:31 PM   #7
Wolfmanjohn
CF Senior Member
Wolfmanjohn's Avatar
Good advice there. My son learned about all the above plus positraction and throttle in the rain after spinning one-and-a-half in his Camaro. Fortunately, it stopped at the "lesson learned" stage.
Wolfmanjohn is offline   Reply With Quote
Reload this Page Tirerack tread depth article
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
