Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2007, 08:15 PM   #1
HECDOGGIE
CF Senior Member
HECDOGGIE's Avatar
Default C6 Wheel swap question?
When swapping out a set of rims, can the sensors be swapped over too (off the stock wheels?)
Sorry, I am a first time vette owner
HECDOGGIE is offline   Reply With Quote
Old 07-16-2007, 10:19 AM   #2
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Yep!
In the stock wheels, the sensors are mounted in the valve stem holes. Some after market wheels don't accept the sensors in their valve stem holes and the sensors have to be mounted inside the wheel with a band or bracket. What wheels are you going with?
Each sensor has a unique ID#, and the TPMS computer in the car knows which # is registered to each corner of the car so the DIC can properly report the tire pressures. When you remount the sensors in your new wheels, get the shop to put the sensor from the Left Front in the new wheel that will go on the LF, the sensor from the old RF into the new RF, etc. If they do that then they won't have to do the "relearn" process to re-register the sensors with the TPMS and your DIC will display the proper pressures. If they mix up the sensors your DIC might say "LF 31 psi", but if that sensor was switched to the RR then the DIC is really telling you what the RR pressure is.
It isn't a big deal if they mix up the sensors - they should have a tool to do the relearn procedure and it only takes a minute or two.
So....if you're just getting a new set of wheels that you will be running all the time, just remount your old sensors in your new wheels.
If you're getting a set of wheels for track tires and you'll be swapping regularly, there are some other other possible issues about running without sensors. If you do swap wheels/tires regularly and both sets have sensors, you'll probably want to get your own tool to do the relearn procedure when you swap.
Bob
BEZ06 is online now   Reply With Quote
Old 07-16-2007, 10:15 PM   #3
HECDOGGIE
CF Senior Member
HECDOGGIE's Avatar
Great info!
I am looking at getting a set of stock chrome to swap out my stock silver......
Old 07-16-2007, 11:02 PM   #4
BEZ06
Formerly beezeye
BEZ06's Avatar
Great info!
Then you'll have no problem!
Below are pictures of the sensor in a stock wheel:
Although you won't need to reset the TPMS if your sensors are mounted back on the same corner of the car they were originally on, you can click on the video link below to see one of the various types of sensor reset tools in use:
Bob
Old 07-23-2007, 11:59 PM   #5
fat bob
CF Senior Member
Great info!
When it comes to wheels and tires, beezeye is "THE MAN"
Great info as usual.
Bob
fat bob is offline   Reply With Quote
Reload this Page C6 Wheel swap question?
Tags
c5, c6, corvette, swap, swapping, track, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Thoughts On $75-85K Pricing w/ Motor Trend Article Out Mike@NorrisMotorsports C6 Z06 Discussion 17 01-05-2005 12:06 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
