Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-13-2007, 06:55 PM   #1
sdspeed
CF Senior Member
sdspeed's Avatar
Default Backwards Tire Question
thanks upfront on this one... I have a virtually new set of Firestone Firehawk SZ50 tires 275/40 18 rears and 245/45 17 fronts.
Problem is I just put a used set of ZO6 rims on that are an inch wider than my stock C5 Speedlines, The Goodyear Eagle F1's that are on the rims are almost shot, also they are 295/35 18 rears and 265/40 17 fronts.
Can I use the Firestones with the obvious size difference or do I have to cough up the coin for another set of tires even though I had no complaints with the Firestones?
Thoughts/Suggestions/Comments/Wanna buy some C5 2001 Stock rims with Firestone tires?
Thanks!
sdspeed is offline   Reply With Quote
Old 07-14-2007, 10:27 PM   #2
JBS11
CF Senior Member
JBS11's Avatar
If you are running the same size rim/tire combo on the same axle, then you are okay. But mixing sizes on the same axle can be a little dangerous and can potentially damage your rear. The smaller tires should fit, but shoukd fit. The snob in me says that it is a Corvette and not a Yugo... so drop the green and make it look right.
JBS11 is offline   Reply With Quote
Old 07-14-2007, 11:05 PM   #3
sdspeed
CF Senior Member
sdspeed's Avatar
It was never about mixing tires or sizes. Just wanna to know if the C5 Fiestone tires that are like new would fit the ZO6 rims. Plain an simple!
Old 07-16-2007, 10:02 AM   #4
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
tire specs
245/45-17 Rim Width Range...... 7.50 to 9.00
275/40-18 Rim Width Range...... 9.00 to 11.00
wheel spec
front = 17x9.5
rear = 18x10.5
so, the fronts would not fit the wheels correctly and the rears would ..... so, I guess we are back to the mixing and matching question ...
Luke@tirerack is offline   Reply With Quote
Reload this Page Backwards Tire Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Winter Driving Wingrider C6 Corvette General Discussion 63 12-20-2004 09:19 PM
hooker side exhaust question randexter1969 C3 Tech/Performance 9 05-13-2004 09:26 PM
Anyone driving without a spare tire? Garson C3 Tech/Performance 40 11-17-2002 10:52 AM
Another stupid question that I can't find an answer to... RMVette C5 Tech 9 07-29-2002 09:59 AM
West Coast Corvette Challenge...coming soon! gary brown Southern California 139 05-02-2002 06:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
