Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Old 07-09-2007, 11:11 PM   #1
jon c
CF Senior Member
2002 Chevrolet Corvette
jon c's Avatar
Default 295's on 19x11
will the 295 tire look to narrow on an 11' wide rim, I dont want the tire sticking out of the fender, thought a 305 may be to wide???
jon c is offline   Reply With Quote
Old 07-10-2007, 10:38 AM   #2
ccdan
CF Senior Member
ccdan's Avatar
What brand/model tire? some run wider than others and some run smaller.
ccdan is offline   Reply With Quote
Old 07-11-2007, 02:13 PM   #3
GotVett?
CF Senior Member
GotVett?'s Avatar
Quote:
What brand/model of wheel also? The offsets will determine where they sit as well.
GotVett? is offline   Reply With Quote
Old 07-11-2007, 04:17 PM   #4
Singer Island C5
CF Member
It seems like all the 19x11 wheel/tire sets being marketed offer 305's, so I'd assume that there aren't any fitment issues. There, I actually typed the word FITMENT! Does any one ever use words like this outside of CF?
Singer Island C5 is offline   Reply With Quote
Old 07-12-2007, 12:06 AM   #5
jon c
CF Senior Member
jon c's Avatar
I'm thinking about the WELD EVO BC-10 wheel has an offset of +65mm,
dont really know what tire to go with maybe the PS2's
Old 07-12-2007, 12:36 AM   #6
GotVett?
CF Senior Member
GotVett?'s Avatar
Might want to check out that particular offset, just to make sure. However, it might be just fine for that wheel.
Old 07-12-2007, 08:16 AM   #7
sonomacrew01
CF Senior Member
sonomacrew01's Avatar
Send a message via AIM to sonomacrew01
I'm running a 295 michelin on a 19x11 Iforged. 275 on a 19x10. Look's great.
sonomacrew01 is offline   Reply With Quote
Old 07-12-2007, 10:13 PM   #8
chuck1026
CF Senior Member
Cruise-In II Veteran
chuck1026's Avatar
As in my PM... Running the C6 EMT's(245/40/18 and 285/35/19) on 18x9.5" and 19x11" CCW's... looks and works fine
__________________
Ombrophobic 2001 Torch Red Coupe - 6 Speed w/ Z51
Mods:
  • CCW SP500's w/ engraved C5 logos, 18x9.5", 19x11"
  • 245/40/18, 285/35/19 GY SC EMT's
  • Hotchkis sway bars
  • Z06 air box & Ti Exhaust
  • Red calipers w/ AC ceramic pads
  • Lowered 1/2"
  • "Nasty98" Rocker Savers
  • Elite gas pedal
"Wind in my hair; Shifting and drifting; Mechanical music; Adrenaline surge."
Rush-"Red Barchetta"
chuck1026 is offline   Reply With Quote
Old 07-14-2007, 11:28 PM   #9
valdeztke
CF Senior Member
Send a message via AIM to valdeztke
Well I put a set of 325/30/19 GY runflats on my 19x11 ... not a good idea. Sidewall is HUGE!!!
After seeing your C6 rear 285/35/19 I think I'll pick up a used set from the C6 forum.
What do you think dan? Can I run the 285/35/19 on a SP20 19x11?
valdeztke is offline   Reply With Quote
Old 07-17-2007, 11:32 PM   #10
jon c
CF Senior Member
jon c's Avatar
well according to John and Chip at CCW they are sending my wheels with 305/30/19 Bridgestones and they said it will fit inside the fenderwell without any issues
Old 07-18-2007, 11:44 AM   #11
jittrbugg
CF Senior Member
Send a message via AIM to jittrbugg Send a message via MSN to jittrbugg
You can run it, it will look like Chuck's car. But I'm a girl bigger is better!
I think the 305's look good on a 19x11. Just my 2 cents.
__________________
Melissa
CCW
jittrbugg is offline   Reply With Quote
Old 07-18-2007, 11:15 PM   #12
LS1 REDBIRD
CF Senior Member
LS1 REDBIRD's Avatar
I run 295/35/19's with a standard offset ZO6 wheel. They rub slightly on the rear brake ducts during hard cornering.
LS1 REDBIRD is offline   Reply With Quote
Old 07-19-2007, 03:31 AM   #13
striper
CF Senior Member
striper's Avatar
I have 295 PS2's on 11" and they fit fine.
striper is offline   Reply With Quote
Old 07-25-2007, 12:47 AM   #14
M396 #00-011
CF Senior Member
M396 #00-011's Avatar
Huge sidewall, not really. 285/35's look like rubber bands. The larger sidewall will ride better.
I would hate to think what you would say about my 345/30's.
__________________
2000 Mallett FRC
Mallett 396's Garage
M396 #00-011 is offline   Reply With Quote
Old 07-25-2007, 01:47 PM   #15
chuck1026
CF Senior Member
chuck1026's Avatar
Quote:
The rolling diameter of the 285/35/19 and 325/30/19 are the same (well, so close it is insignificant).
Translation: Sidewalls are the same height.
Old 07-25-2007, 03:46 PM   #16
M396 #00-011
CF Senior Member
My bad, I read 285/30/19, thinking 26" sidewall. I even wrote it correctly too. Nevermind.....
So if it's the same sidewall height, it must be that the section width is 13.2" on a 11" rim. The wheel itself is still 12", so the tire shouldn't really hang over much. I'd intrested to see how it really looks.
Old 07-25-2007, 10:18 PM   #17
valdeztke
CF Senior Member
Well I swapped my 325-30-19 for 285-35-19 today on my CCW 11.5 and it is exactly the look I was going for
BEFORE
AFTER
Reload this Page 295's on 19x11
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
