Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2001, 04:07 PM   #1
NavyVet
CF Senior Member
NavyVet's Avatar
Default Luke - availability of Kuhmo ECSTA 700s in 315/35x17?
I will need new ones very soon and would like to try the new ones instead of Victoracer v700s.
Also, can I reverse victoracer v700s and use the remaining inside rubber that way? Or, is there a design issue that would make this hazardous? I was thinking of taking the right front/rear to mount the other side out on the left front/rear so their directions wouldn't change; and vice versa. Thoughts? Thanks.
NavyVet is offline   Reply With Quote
Old 10-30-2001, 03:45 PM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
Default Re: Luke - availability of Kuhmo ECSTA 700s in 315/35x17? (NavyVet)
I heven't recieved any update on the new Ecsta V700's in 315/35-17 yet. ... I do have the Victo-Racers available at this time
Luke
877-522-8473 ext. 362
Luke@tirerack is online now   Reply With Quote
Old 10-30-2001, 11:07 PM   #3
JasonL
CF Senior Member
Send a message via AIM to JasonL
Yes, this is very common practice.
The tires are not directional either (ignore the left/right markings) so you don't need to run them the same direction.
Basically, you can run the tires in any configuration you want. Tire Rack has an article detailing this.
JasonL is offline   Reply With Quote
Old 11-05-2001, 11:45 AM   #4
NavyVet
CF Senior Member
NavyVet's Avatar
Default Re: Luke - availability of Kuhmo ECSTA 700s in 315/35x17? (JasonL)
Jason, thanks a lot. I have seen people do it, but wanted a second opinion. I did know about the directional issue as both my rear 315s are the same! Thanks again. I will swap and get a few more runs!
Reload this Page Luke - availability of Kuhmo ECSTA 700s in 315/35x17?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
