Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-22-2001, 09:43 PM   #1
79Corvette02
CF Senior Member
79Corvette02's Avatar
Default 2000 Rims on old school C3
I have a 79 Vette, and I'm tiring of the stock rims w/ the spinners. I'm looking for a bigger wheel and smaller tire (in terms of sidewall height)-something along the lines of 17x9 or 17x10. I love the look of the 2000 Corvette wheels. What are the chances that these would fit my car w/ a few minor modifications (i.e. having them redrilled for my bolt pattern?). ???? :confused: :confused:
79Corvette02 is offline   Reply With Quote
Old 10-23-2001, 09:45 PM   #2
joalyons
CF Senior Member
Send a message via AIM to joalyons
Default Re: 2000 Rims on old school C3 (79Corvette02)
Im not sure what offset would fit but you will need to purchase adapters (like the ones offered by Vette Brakes) because the C4 and C5 wheels have a negative offset your vette uses more of a positive offset (I might have them mixed up C4/C5 wheels stick in C3 wheels stick out). I know it can be done, I have seen 2nd Gen Camaro's with C4 wheels so if they can you can. What you need to do is check how much room you have between the mounting point for the wheel (the drum or disk) and the fenderwell (both inner and outer). From there get the dimension of the wheel you are looking at (ie 17x9.5) and the offset. For expample if you are looking at the ZR-1 type wheel they are 17x9.5 and 36mm or 50mm offset (36 or 50mm back from the centerline of the wheel). That will tell you what spacers you need. Best bet, find someone with a C4 or C5 wheel and do some test fitting (it probably wont bolt up but you can get the idea) then do your measurements from there.
Joe
joalyons is offline   Reply With Quote
Old 10-25-2001, 10:38 PM   #3
70 LS1
CF Senior Member
70 LS1's Avatar
The bolt pattern is the same 5 x 4.75. you would need 3" adapters to get the backspacing correct.
70 LS1 is offline   Reply With Quote
Reload this Page 2000 Rims on old school C3
Tags
2000, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear Wheel Spindle/bearing(s)/trailing arm repair - pictures verskel C3 Tech/Performance 9 04-10-2002 02:06 PM
Interesting Engine Parameters Question from the C3 Forum.... lars C1 & C2 Corvettes 13 11-08-2001 09:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
