Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-20-2007, 11:54 AM   #1
viper8u2
CF Senior Member
viper8u2's Avatar
Send a message via ICQ to viper8u2 Send a message via AIM to viper8u2 Send a message via MSN to viper8u2 Send a message via Yahoo to viper8u2
Default Another tire/wheel question
2001 MN6 Coupe---
I am thinking about getting some cheaper wheels (I can't afford to spend alot right now). (Ruff Racing 278 Hyperblack)
Is there any issue of running 19" wheels all around? I searched the forum and see alot are running 19" or 20" with no issues. Is this a correct assumption? Or should I run 19x9.5 rear and 18x8.5 front?
Also, the wheels are not as wide as I would like them to be but for the price I can over look. I have choices of 19x9.5 and 19x8.5. I was thinking of running the 19x9.5 in the rear and 19x8.5 in front or should I run the 9.5 width all around?
Lastly, what would be the best sizes to run for these wheels? What are the largest sizes I can get on these wheels?
18x8.5 - front
19x8.5 - front
19x9.5 - rear
Thanks for any insight
Mike
viper8u2 is offline   Reply With Quote
Old 04-20-2007, 02:18 PM   #2
ICaughtVetteFever
CF Senior Member
ICaughtVetteFever's Avatar
19" all around is fine, just make sure when you buy tires the diameter of the front is between 1/2"-1" less than the rear. Most stagger the wheel size for looks, that is why the factory did it. I would go with 9.5 all around, I run that as my front and 11.5 on the rear. a 285/30/19 in rear, and 265/35/18 front or close would be fine. You could also do 285 all around, but bigger fronts are not really needed on the street.
ICaughtVetteFever is offline   Reply With Quote
Old 04-30-2007, 07:49 PM   #3
viper8u2
CF Senior Member
viper8u2's Avatar
Quote:
Thanks,
got 19" x 9.5 45mm offset all around, should be here Thursday
Would I have problems running the BFG KDW2's
Front - 265/30 ZR19 - Rim width range 9-10" Overall Diameter 25.4"
Rear - 295/35 ZR19 - Rim width range 10-11.5" Overall Diameter 27"
Or should I go with the 255/35/19 for the fronts?
Is 265 too wide? I don't want to worry about rubbing
I want to order these tonight so I can get them mounted this weekend
Thanks,
Mike
Reload this Page Another tire/wheel question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C3 Tire/wheel question... GrandSportC3 C3 Tech/Performance 37 05-18-2003 10:59 PM
Another Tire Size Question Viet Nam Vett C1 & C2 Corvettes 11 05-15-2002 08:38 PM
Yet another Richmond Trans question 69L71 C3 Tech/Performance 24 02-09-2002 04:03 PM
Another Tire Question, But I Think Different ? Glennm27 C5 Tech 17 01-23-2002 12:13 PM
Another rear wheel bearing question.. Eric Fraser C4 Tech/Performance 17 11-07-2001 07:04 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
