Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-20-2007, 08:43 AM   #1
MyFirstCorvette
CF Senior Member
MyFirstCorvette's Avatar
Default Will a slightly taller front tire cause ABS/AH or handling issues?
Hello,
I have a 2000 FRC and am thinking about purchasing 315/30/18's (diameter of 25.35") for the back and 275/40/17's (diameter of 25.55") for the front.
Will I have any issues with the ABS, Active Handling or handling in general because the front tires are slightly taller than the rears?
As time goes on I would imagine the rears will wear faster than the fronts so the difference might be slighly more pronounced due to aggressive driving.
Thanks in advance!
__________________
[IMG]2000 White Corvette FRC - Was Bone Stock! Road Race LS3 assembled, installed and tuned by Dr. Phil!
MODS ALMOST FINISHED!
MyFirstCorvette is offline   Reply With Quote
Old 04-20-2007, 10:11 AM   #2
UstaB-GS549
CF Senior Member
UstaB-GS549's Avatar
I suspect not, but can't say for sure.
I ran 315's front and rear last year. The fronts are on 9.5" rims which tends to make tire taller than rears on 11" rims.
A lot of guys run equal diameters with no problem.
UstaB-GS549 is offline   Reply With Quote
Reload this Page Will a slightly taller front tire cause ABS/AH or handling issues?
Tags
back, front, slightly, taller, tire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
