Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2007, 07:39 PM   #1
cooken
Junior Member
cooken's Avatar
Default TPM Alarms on new Kumho MX
Got 2004 C5 back yesterday after getting new set of Kumho MX installed. Today the TPM started alarming that tire pressure was to high. Does TPM have an upper limit set for tire pressure or does the upper threshold change when TPM is reset?
cooken is offline   Reply With Quote
Old 04-18-2007, 09:44 PM   #2
yaonttwo
CF Senior Member
yaonttwo's Avatar
Yes it does have an alarm. Pressure should be 30lbs cold.
yaonttwo is offline   Reply With Quote
Old 04-19-2007, 10:15 AM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
I would be willing to bet that the shop looked at the sidewall of the tire where is says "maximum inflation pressure 51 psi" and set the pressure at 51 psi .....
lower the pressure and you should be fine
Luke@tirerack is offline   Reply With Quote
Old 04-19-2007, 11:46 AM   #4
cooken
Junior Member
cooken's Avatar
Shop guy set them to 43. I found out the following thresholds exist inthe DIC for TPM:
<5 psi - Flat Tire warning message is displayed
5-25 psi - Low Tire warning message is displayed
26-42 psi - normal condition,no messages
>42 psi - High Tire warning message is displayed
I am trying to find out if the thresholds can be adjusted up, and also what an optimal PSI for road versus track is.
Reload this Page TPM Alarms on new Kumho MX
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
