Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-17-2007, 02:27 AM   #1
benspruce
CF Senior Member
benspruce's Avatar
Default Does Michelin make runflats for a base C6?
I'm looking for some good mileage, quiet runflats. Does Michelin or anyone else other than Goodyear and Firestone make runflats for the C6 (non Z51). Thanks
benspruce is offline   Reply With Quote
Old 04-17-2007, 10:52 AM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
not at this time .. .The Firestone Wide Oval Runflat is a smooth, quiet tire which is a significant upgrade from the OE Goodyears
Luke@tirerack is online now   Reply With Quote
Old 04-26-2007, 02:43 PM   #3
herkdriver
Junior Member
herkdriver's Avatar
Default Looking for C6 Z51 Runflat Replacements
Luke - New guy to the forum with a similar question... I've got a C6 Z51 with worn out stock GY F1 Supercars (cords on the inner edges of the fronts really snuck up on me!). Looking for a good replacement... sounds like the Firehawks, Michelins, Falkens, and Nittos are a few options but I'm only just starting the research... any advice? I'm pretty much a daily driver who occasionally opens it up, but no track time - I'd rather have treadlife & all-weather capability over supertraction & rapid wear. Also, I understand that the 'aggressive alignment' on the Z51 that causes the premature inner front wear can be taken out... do you recommend this, or know if any warranty issues that it may create?
herkdriver is offline   Reply With Quote
Old 04-27-2007, 07:07 AM   #4
chuck1026
CF Senior Member
Cruise-In II Veteran
chuck1026's Avatar
Quote:
I'm not Luke, but negative camber and some toe are what tore up you Goodyears.
Go to a good alignmnet shop (one that really knows Corvettes) and have them set it up with a street setting... If it is anything like my C5, you want about -0.18º of camber front and rear along with 0 to 1/32" of toe.
Your C6 will still handle great, but you won't burn down the inner edges of your tires prematurely, be them Goodyears or anything else in an EMT.
Alignment changes will not void the factory warranty. If anything, once you get your new alignment printout (with the original settings on it as well), you will find out how sloppy BG was when they built your C6.
Chuck
__________________
Ombrophobic 2001 Torch Red Coupe - 6 Speed w/ Z51
Mods:
  • B&M Ripper shifter
  • CCW SP500's w/ engraved C5 logos, 18x9.5", 19x11"
  • 245/40/18, 285/35/19 GY SC EMT's
  • Hotchkis sway bars
  • Z06 air box & Ti Exhaust
  • Red calipers w/ AC ceramic pads
  • Lowered 1/2"
  • "Nasty98" Rocker Savers
  • Elite gas pedal
"Little red Corvette, baby you're much to fast (yes you are)" --- Prince or whatever he calls himself now
chuck1026 is offline   Reply With Quote
Reload this Page Does Michelin make runflats for a base C6?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Regarding Replacement Fun Flats AC54ME C5 General 44 11-29-2004 09:04 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
