Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2007, 12:41 AM   #1
brad6285
CF Senior Member
Default wheel spacers
i put new rims on my 03 ae vert and they seem to sit to far inside the wheel well. i have 3/8 drm spacers and my question is with the 3/8 spacer do you have to put longer wheel studs in? thanx brad
brad6285 is offline   Reply With Quote
Old 04-09-2007, 04:16 PM   #2
Randy@DRM
Premium Supporting Vendor
Randy@DRM's Avatar
Double check, but I am 99.9999999999999% sure you will need longer studs to ensure proper thread engaugment.
Randy
Randy@DRM is offline   Reply With Quote
Old 04-10-2007, 04:10 PM   #3
steponc
CF Senior Member
Support Corvetteforum!
steponc's Avatar
Default Spacers
I tried to use 1/4 " spacers on the rear and the studs were too short. This was with aftermarket wheels. I have used a 1/4" spacer on the front without longer studs but have since changed all of the studs to a longer length.
steponc is offline   Reply With Quote
Old 04-10-2007, 04:57 PM   #4
ccajun4real
Supporting Vendor
St. Jude Donor '04-'05-'10-'11-'12
ccajun4real's Avatar
@beracing
Quote:
Where did you get the studs? How much $$$ were they? How hard to install? Are spacers safe at high speed? Thanks
Cajun
ccajun4real is offline   Reply With Quote
Old 04-11-2007, 05:29 PM   #5
steponc
CF Senior Member
steponc's Avatar
I ordered from DRM (see above thread) They weren't cheap but very nice product compared to the parts house type the tire shop installed until I received the others. The studs are chrome-moly and the ratings are greater than the factory studs. The spacers are a strong aluminum alloy and are hub-centric. The studs weren't hard to change, just remove the caliper and rotor. I used a brass drift on the stud with a lug nut to knock the factory studs out and installed the long studs.
Reload this Page wheel spacers
Tags
2007, 38, c4, corvette, spacers, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wheel Spacers OK? SkunkApe C3 Tech/Performance 43 06-08-2005 01:09 AM
Wheel spacers or adapters MYBAD79 C3 Tech/Performance 10 01-19-2005 04:21 PM
wheel spacers instead of offset trailing arms supervett77 C3 Tech/Performance 11 11-03-2004 07:53 PM
Do You Use Wheel Spacers? OHSIXX C3 Tech/Performance 30 05-25-2004 07:54 PM
wheel spacers....safe? SharkBit C3 Tech/Performance 15 08-28-2003 09:38 PM
Wheel Spacers OHSIXX C3 Tech/Performance 13 11-01-2002 11:23 PM
what do you think about wheel spacers? morphious C4 Tech/Performance 11 08-16-2001 02:26 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
