Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-07-2007, 05:03 PM   #1
rcarbonetti
CF Senior Member
Default C6 Tire size ? 255/35/18 & 285/30/19 on C6 wheels OEM -Any problems?
I have some OEM C6 wheels 18x8.5 &19x10. I have 2 Dunlop SP 9000 rear tires 285/30/19 for the rear wheels. I am considering the Dunlop SP9000 in the 255/35/18 for the front set. Will this work without causing any problems in active handling or othe areas of the car.
The combination would be on a 2000 convertible. Thanks in advance for the forums help.
Here are the specs from Tire Rack:
255/35 ZR18
SL 280 AA A
1323 lbs.
51 psi
10/32"
24 lbs. NA
9" the C6 wheel is 8.5"
10.2"
9.1"
25"
832
285/30 ZR19
SL 280 AA A
1477 lbs.
51 psi
10/32"
28 lbs. NA
10"
11.1"
NA
25.9"
NA
rcarbonetti is offline   Reply With Quote
Reload this Page C6 Tire size ? 255/35/18 & 285/30/19 on C6 wheels OEM -Any problems?
Tags
18, 2000, 25535, 28530, 2853019, 35, c6, corvette, dunlop, front, rear, size, sp, specs, tire, tires, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
