04-04-2007, 01:26 AM
CF Senior Member
Cruise-In II Veteran
Does a 275/35-17 tire even exist? I'm not aware of that size being made (at least by the bigger mfrs.).
As to whether either tire would fit a 8.5" width wheel, it will go on, but almost all 275 width tires spec out a minimum of a 9" wide rim.
04-04-2007, 01:32 AM
CF Senior Member
Quote:
Originally Posted by
wamara
yeah its made...and i think your right 1 inch is all they spec at over the rim width
04-04-2007, 01:39 AM
CF Senior Member
rustyguns
Who makes that tire size (and model)? I'm curious to know....
04-04-2007, 02:08 AM
CF Senior Member
wamara
sorry 18's...... 17's would be 40
04-04-2007, 02:12 AM
CF Senior Member
best i can figure is..... it one inch per side or a total of one inch tire width more than the rim?
think i may have to go 285/30/18's all around
would they be OK on a 9.5 rim?
hoosier charts says 10 inch but the next size up 295/30/18 hoosier says 9.5 is ok...maybe a typo?
stock is 275/30/18...seems like you could squeeze a 285/30/18 on there
04-04-2007, 04:43 AM
CF Senior Member
285/30 is way too low diameter to run on the rear, and too low in the front also. You want to stay within 3% of OEM diameter. A 285/35/18 would work, I use that size Nitto RII on my front and 305/35 out back. I run the 285s on 9.5s, though a 10 would be better
04-04-2007, 02:16 PM
CF Senior Member
ICaughtVetteFever
i am tying to run all 4 tires the same and yeah it looks like i am going to have to go 18's because the 17's i got are too skinny
i am still trying to see if i can get away with 275/40/17 on a 8.5x17 rim, but it looks hopeless
04-04-2007, 04:17 PM
CF Senior Member
rustyguns
They will fit, but will buldge and not handle or look good as good as they would on a bigger rim and you will loose contact area.
04-05-2007, 04:49 AM
CF Senior Member
ICaughtVetteFever
yeah ur right
i may use the 4 17's in 245/40/17 size for street-maybe- and then use the 4 285/3018's for de events
Tags
17 , 17x85 , 275 , 2753517 , 40 , c3 , corvette , inch , rim , size , tire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
Thread
Forum
Replies
Last Post
Width of tires?
C4kid94
C4 Tech/Performance
14
11-21-2002 06:13 PM
