Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-28-2007, 12:17 AM   #1
VinceC5
CF Senior Member
VinceC5's Avatar
Default C6 wheels on a C5 -- any issues?
So I know the offset is different, but what does that mean. I've heard some say there are no issues, others say don't do it?
What issues do I need to worry about? These are the standard wheels, not the z06. They are on a 2001 C5 coupe.
VinceC5 is offline   Reply With Quote
Old 03-28-2007, 01:47 PM   #2
fat bob
CF Senior Member
VinceC5, I did this on a friends '01 C-5 Coupe.
Stock C-5 sizes are overall identical to C-6. DIAMETER wheel and tire
C-6 TPS will not work on C-5's but C-5 sensors will work in C-6 wheels and vice versa.
1. There are no computer or speedometer issues.
2. AH, TC, ABS, will work without problems. Stager is fine.
3. Front wheels will bolt on and fit, run, and look perfect.
The rear wheels are the only issue. Since I have only tried this with one car I can't be called an expert. The rear stock C-6 wheels on the C-5 that we tried do not fit perfectly.
The problem is the increased offset and the additional sectional width. On our trial C-5, the rear wheels had MINIMUM clearance between the tire and the inside fender well. There are other Forum members who posted that there were no issues and I can't argue factually with their results.
If my results were typical, to put C-6 wheels on a C-5 will probably require a spacer for the rear only of approximately 1/2" and change the TPS.
Hope this helps you.
Bob
fat bob is offline   Reply With Quote
Old 03-28-2007, 09:45 PM   #3
VinceC5
CF Senior Member
VinceC5's Avatar
Bob,
Thanks for the information.
It is very helpful.
I see some chrome C6 wheels on my C5 in the near future...
Old 03-28-2007, 11:28 PM   #4
fat bob
CF Senior Member
Bob,
It is very helpful.
You are welcome Vince. I am sure there are lots of repros in C-6 style with C-5 offsets which would mean that you could do without the spacer in the rear. From a resale standpoint I think I would prefer the factory C-6 in chrome.
Bob
Old 03-29-2007, 04:40 AM   #5
99FewteRC5
CF Senior Member
99FewteRC5's Avatar
I have OEM C6 wheels on my 99FRC. Heres a few pics
5/16 spacer (if i remember right) less than 1/4 inch-still hub ecentric
spacer on the rear was not necessary but looked better
99FewteRC5 is offline   Reply With Quote
Old 03-29-2007, 04:40 AM   #6
99FewteRC5
CF Senior Member
99FewteRC5's Avatar
Old 03-29-2007, 12:18 PM   #7
fat bob
CF Senior Member
99FewteRC5,
Thanks very much for the information. I have a set of comp gray wheels with just under 1,100 miles with the much better C-6 Runflats mounted on them that I would like to offer C-5 owners for sale.
I am guessing that the 5/16th spacer did not require studs. Is that right?
Also, can you tell me, (and it would help Vince above) where you got that spacer. I would like to buy a set and include that in the deal to a C-5 owner as a package.
Thanks very much,
Bob
Old 03-29-2007, 08:04 PM   #8
99FewteRC5
CF Senior Member
99FewteRC5's Avatar
You are correct. I did not replace the stucs. They are factory studs. I dont remember where i got the spacer, but any auto supply store or even wheel and tire shops should have them. The spacer is less than 1/4 inch, the one i have may be in millimters. But around 5/16. Just get one that is a tad thinner than 1/4. I've seen these wheels installed on C5's without spacer also.
Old 04-17-2007, 03:03 PM   #9
bassvet
CF Senior Member
St. Jude Donor '10
bassvet's Avatar
No spacers no problems. yet, 06 OEM polished..... OPP'S, inside tire rub had to go with a 1/4" spacer.... Seems to be fine now......
__________________
"Never drive faster than your guardian angel can fly"
2004 Commemorative Edition Cpe
2004 Spiral Grey Cpe
2006 Machine Silver Convertible
2010 Cyber Grey Grand Sport
2009 Silver/Ebony Cadillac XLR V
2010 SRX AWD TURBO
www.gacorvettes.com
NCM Member
Grand Sport Registry 00516
bassvet is offline   Reply With Quote
Old 04-22-2007, 11:24 PM   #10
VinceC5
CF Senior Member
VinceC5's Avatar
Got them finally!! 1/4 spacer for the rears...
Old 04-23-2007, 03:08 AM   #11
Winterlude
CF Senior Member
Winterlude's Avatar
wow i came here to post a thread asking this exact question I guess that covers everything for me too. Just one question though, does adding a spacer have any side effects at all? I remember dealing with offset on a honda way back and was told that it may cause uneven wear on the ball bearings. something about the wheel puts more pressure on the outside bearing than the inside one. maybe this doesn't apply to vettes, also i recall it had to do with the front wheels. Does anybody know anything about such a thing existing?
Winterlude is offline   Reply With Quote
Old 04-25-2007, 02:31 PM   #12
Winterlude
CF Senior Member
Winterlude's Avatar
ok one more question maybe someone can answer this one. to anyone who put c6 wheels on their c5, was you car lowered? Mine's lowered on stock bolts, i'm guessing since the overall diameter is the same that it wouldn't affect it, but have to ask anyway.
Old 04-27-2007, 03:31 PM   #13
99FewteRC5
CF Senior Member
99FewteRC5's Avatar
not a prblem with lowering on c6 wheels
Old 04-27-2007, 09:01 PM   #14
Winterlude
CF Senior Member
Winterlude's Avatar
good to hear
btw i just did the calculations on both cars' stock tires diameter and the C6 wheel with tire is slightly bigger in the rear and front, not by much, 1/2 inch, at the most it might register 1 click slower on the speedo, no big deal.
Old 04-30-2007, 08:33 PM   #15
Winterlude
CF Senior Member
Winterlude's Avatar
Ok I'm not going to make a new thread about this but just an FYI for anyone thinking of putting C6 wheels on their C5, I just came back from my mechanic and at least in Ontario and I would suspect maybe other states and provinces, putting spacers on wheels is illegal. Unless, you put a spacer kit that basically extends the hub and is a whole bolt on assembly.
My mechanic explained to me that you couldn't pass a safety test, required here, and you apparently would be denied insurance coverage should a wheel come off or an accident happens due to the modified wheel. I don't know how big the "real" risk is, but you may have some problems with the legalities at the very least. I wouldn't worry about it if you have them on already but if you're about to you may want to check it out. Just throwing it out there for those that may need it.
Reload this Page C6 wheels on a C5 -- any issues?
Tags
c5, c6, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
Ken's Weekly News-12/5/03-C6 News, GMPP Sale, Corvette Sale, Parts Sale! Ken Fichtner Ken's Newsletters 15 01-03-2004 01:13 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
