Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-20-2007, 02:24 PM   #1
Black04Vert
CF Senior Member
Default Non-runflats may harm tire pressure sensor?
A rep at Discount Tires told me that non-runflat tires on some types of cars will ruin the tire pressure sensors if they go flat because the non-runflat sidewall will collapse enough for the sensor to be damaged.
Does this apply to the C6 or are the valve mounted sensors deep enough that they are protected by the lip of the wheel?
Black04Vert is offline   Reply With Quote
Old 03-20-2007, 02:58 PM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
I don't know how probable it is, but I'm sure it's possible.....
leadfoot4 is offline   Reply With Quote
Old 03-20-2007, 03:49 PM   #3
fat bob
CF Senior Member
[quote=Black04Vert;1559447335]A rep at Discount Tires told me that non-runflat tires on some types of cars will ruin the tire pressure sensors if they go flat because the non-runflat sidewall will collapse enough for the sensor to be damaged.
Does this apply to the C6 or are the valve mounted sensors deep enough that they are protected by the lip of the wheel?[/QUOTE
Black04Vert, I have done two C-6 wheel changes all around and installed the sensors myself. They fit close to the wheel and although I could not say for certain I think it would require the tire to be really flat and driven for a long period. Even the non runflat tires for these cars have stiff sidewalls in order for them to carry a "Y" rating (speed).
There is a Forum member named Breyzee (not sure about spelling) that is very knowledgeable about wheels and tires and his opinion is probably much better that mine. I hated the C-5 runflats and took them off as soon as I could. The C-6 are much better and I am back to runflats on the C-6.
Bob
fat bob is offline   Reply With Quote
Old 03-20-2007, 04:06 PM   #4
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Like Fat Bob says, I think they'd have to be really flat, or the sidewall would have to come off the bead or shred for the sensors to be damaged.
A blowout with a rapid loss of pressure would be more likely to create a problem, but with a slow leak the sensors will let you know in advance so you can catch it before a problem gets too bad.
Below is a picture of how they mount in the stock wheel. If you've got them in aftermarket wheels or banded inside you might have more problems.
Bob
BEZ06 is offline   Reply With Quote
Old 03-20-2007, 09:55 PM   #5
fat bob
CF Senior Member
Bob
Thanks Bob, I have read many of your posts but I couldn't remember the exact spelling of your name. I am a wheel nut myself but I thought if you picked this up you could help him with more certainy than I.
Bob
Old 03-21-2007, 02:25 PM   #6
Black04Vert
CF Senior Member
Thanks for the info. I've got 15K on my GS2's and I'm down to 2/32 inch of tread left. Non-runflats give me a lot more options.
Old 03-21-2007, 03:40 PM   #7
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
I have never seen that happen and a huge number of people swap out their runflat tires
Luke@tirerack is online now   Reply With Quote
Old 03-21-2007, 04:17 PM   #8
1stC3Vette
CF Senior Member
1stC3Vette's Avatar
The same sensors are used on runflat or non-runflat tires. We provide tire/wheel equipment to the OEM's and they use the same wheels and sensors with different tires all of the time.
Goodluck,
Dino
1stC3Vette is offline   Reply With Quote
Old 03-22-2007, 09:39 AM   #9
Luke@tirerack
St. Jude Donor '11
there are also vehicles that come with sensors and non-runflat tires from the factory .... I think your guy needs to learn more about his profession before he spouts off with non-factual useless drivel
Reload this Page Non-runflats may harm tire pressure sensor?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
