Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-18-2007, 10:02 PM   #1
JETSWU87
CF Senior Member
Send a message via AIM to JETSWU87
Default 275 run flats on a stock c5 z06 wheel
I purchased my car with pretty good tires on them, but im about to pick up some new wheels c5 z06. In z06 sizes 17x9.5 18x10.5.
I'd like to just transfer my tires from my thin spokes to the z06 wheels, is this possible? I'm thinking it shouldnt be an issue, but since the run flat sidewalls are so stiff, just curious if it'd be a stretching issue for a good bead.
Cliff notes: Will a 275 wide tire fit a 10.5inch wheel?
JETSWU87 is offline   Reply With Quote
Old 03-18-2007, 10:41 PM   #2
chuck1026
CF Senior Member
Cruise-In II Veteran
chuck1026's Avatar
Yes... it is legal.
Per Goodyear:
Stock 245/45/17 can go on a 7" to 9-1/2" rim.
Stock 275/40/18 can go on a 9" to 11" rim.
See http://www.tirerack.com/tires/Spec.j...3D74YR8F1GSEMT
__________________
Ombrophobic 2001 Torch Red Coupe - 6 Speed w/ Z51
Mods:
  • B&M Ripper shifter
  • CCW SP500's w/ engraved C5 logos, 18x9.5", 19x11"
  • 245/40/18, 285/35/19 GY SC EMT's
  • Hotchkis sway bars
  • Z06 air box & Ti Exhaust
  • Red calipers w/ AC ceramic pads
  • Lowered 1/2"
  • "Nasty98" Rocker Savers
  • Elite gas pedal
"Little red Corvette, baby you're much to fast (yes you are)" --- Prince or whatever he calls himself now
chuck1026 is offline   Reply With Quote
Old 03-18-2007, 10:52 PM   #3
JETSWU87
CF Senior Member
Chuck you've been ton's of help on my post
Thanks alot.
Old 03-19-2007, 06:57 AM   #4
chuck1026
CF Senior Member
chuck1026's Avatar
Just sharing what I figured out while shopping for tires and rims. The Tire Rack is a great source for detailed info.
The tires may look a bit stretched on the wheels, as you are at the upper rim size limit. My C6 tires run on the upper end of the spec. and I think they look fine.
Chuck
Reload this Page 275 run flats on a stock c5 z06 wheel
Tags
275, c5, flats, rim, run, stock, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tire perfomance question..30 vs 35 series flynbya2 C5 Tech 20 08-16-2004 12:50 PM
What are the NARROWEST tires and wheels available for drifting in a C5? EHS C5 Tech 23 03-04-2004 07:51 PM
Anyone tried the Halltech Tunnel Ram Air Pak?????? 98vettecpe C5 Tech 28 08-10-2003 06:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
