Quote:
Originally Posted by C6Z512005
"The best and most cost effective repair would be to put the wheel on our CNC Lathe and put a small cut on the edge to remove the damage. Would the small portion that would be lathed off disturb the balance/performce of the wheel/tire?
Probably not the performance, definitely not the balance (especially if they are going to re-balance afterwords).
Would this affect the clear coat and if so, what would need to be done.
It will remove the clearcoat along with the metal..... You might want to have it re-clear coated.
If they did the work, any issues I should be cautious of with the removal of the tires (stock Z51 rubber)....special type of machine to do this, etc...????
Nothing special; same "no-touch" machine any alloy wheel would require.
Larry
code5coupe
