Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-07-2007, 12:10 AM   #1
Ybnormyl
Junior Member
Ybnormyl's Avatar
Default What is the stock tire size for a 94?
Begining to question if someone before me changed the tire/wheel size.
Does any one know what came stock on a 94 Coupe?
Ybnormyl is offline   Reply With Quote
Old 02-07-2007, 09:21 AM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
non ZR1
255/45-17 (F) 285/40-17 (R)
ZR1
275/40-17 (F) 315/35-17 (R)
Luke@tirerack is offline   Reply With Quote
Old 02-07-2007, 11:02 PM   #3
Ybnormyl
Junior Member
Ybnormyl's Avatar
Default Thanks
Thanks,
Now how do I measure the offset on the wheel.
On a 94 I believe it should be 57cm
Is this correct?
Do I measure from the outer rim to the center flange plate on the OUTSIDE of the wheel or the Inside????
Thanks for your help.
Reload this Page What is the stock tire size for a 94?
Tags
1994, 94, corvette, size, standard, stock, tire, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Drag radial for 94 vette question redcorvettedave C4 Tech/Performance 14 01-11-2005 01:46 PM
11.789 @ 117.579 !!!! - NEW 100% STOCK RECORD! vai Performance Results 65 08-12-2004 08:34 AM
Tire Size Questions for 94' n1kki6 C4 Tech/Performance 18 02-18-2003 01:33 AM
do you finish the quarer mile in fourth with a 373gear? blk95 C4 Tech/Performance 16 12-10-2002 03:29 AM
How do I improve the handling feel of a Z06. Red Rotary Rocket C5 Z06 Discussion 48 03-03-2002 11:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
