Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2007, 12:10 AM   #1
Iceman_K
CF Senior Member
Iceman_K's Avatar
Send a message via AIM to Iceman_K
Default 17 x 9.5 & 18 x 9.5 Does this work?
I just bought a set of C6 reproduction Z06 from Corvettes of Houston. I have a C5 Vert. Will this size combo work ok? If yes, what tire sizes do I need? Thanks.
Iceman_K is offline   Reply With Quote
Old 01-13-2007, 12:50 AM   #2
fat bob
CF Senior Member
Quote:
Hi Iceman, just for starters I would look at:
265x40x17 for the front. (Z06 standard front C-5 size tire)
275x40x18 for the rear (standard C-5 rear size.)
Those sizes are a correct factory match for the rim width and the overall diameter will work with AH, TC, and ABS.
I think the front is exactly correct.
A 295x35x18 would be perfect as far as the correct stager is concerned for the rear but I don't know if the 295 is too large for your
9.5" rear rim width. Check with Luke at Tirerack on the rear.
Please post what you end up with.
Bob
fat bob is offline   Reply With Quote
Old 01-13-2007, 12:16 PM   #3
Iceman_K
CF Senior Member
Iceman_K's Avatar
Thanks Bob. For now I have the stock C5 sizes on these rims. The front tires are stretched a bit. It doesn't handle as good as the stock setup did.
Old 01-14-2007, 10:22 PM   #4
KBRVETTE93
CF Senior Member
KBRVETTE93's Avatar
You should be good to go.
KBRVETTE93 is offline   Reply With Quote
Old 01-15-2007, 01:01 PM   #5
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
the C5 OE front tire 245/45-17 max wheel width is 9.0" and that setup would have a detrimental effect on the cars handling .... either replace the front wheels to the proper 8.5" width or buy new front tires
Luke@tirerack is offline   Reply With Quote
Old 01-16-2007, 10:37 AM   #6
Iceman_K
CF Senior Member
Iceman_K's Avatar
Corvettes of Houston took care of it. They swapped the 17x9s for 17x8s without giving me a hard time. The car is handling much better now and I won't need to buy a new set of tires to compensate for the mismatch. Thanks to Mike and everyone at Corvettes of Houston for your help.
Reload this Page 17 x 9.5 & 18 x 9.5 Does this work?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
C5 Stereo Install Lessons Learned (long) (all text) MSIP Audio/Electronics 10 06-10-2004 07:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
