Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-03-2007, 11:13 AM   #1
Mellow- Yellow
CF Senior Member
Cruise-In VII Veteran
Support Corvetteforum!
Mellow- Yellow's Avatar
Default Is 35 LBS Too Much?
I had new wheels installed a few days ago and the guy at the tire store put 35# in. I asked him about it and he said that is what it should have. I had nitrogen put in the tires. Right now I am in Florida and the temps are 80+ degrees during the days. In a few days I will be driving back to Kentucky. Should I let some air out of the tires or wait until I get back to KY and check them in cooler weather? Since he put nitrogen in, should the tires have more or is this too much? I will be dirving about 1000 miles to get home and do not want to hurt my tires!
Mellow- Yellow is offline   Reply With Quote
Old 01-03-2007, 11:33 AM   #2
chemten
CF Senior Member
chemten's Avatar
Send a message via ICQ to chemten Send a message via AIM to chemten Send a message via MSN to chemten Send a message via Yahoo to chemten
that seems high. my pressures are usually 28 or 29 cold and move up from there when it's warmer outside or i'm at highway speeds.
chemten is offline   Reply With Quote
Old 01-03-2007, 11:47 AM   #3
UstaB-GS549
CF Senior Member
UstaB-GS549's Avatar
As long as the sidewalls list a pressure higher than 35 at max load capacity, the only downside is ride quality. My guess is that the max pressure is something like 44 psi.
Generally, steering response, cornering and hydroplaning resistance all improve with increasing tire pressures.
UstaB-GS549 is offline   Reply With Quote
Reload this Page Is 35 LBS Too Much?
Tags
1600hp, corvette, weather
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Has anyone installed an LS1 in a C4? How much weight is saved? jz94 C4 Tech/Performance 83 06-28-2011 02:53 AM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
WOOT!!! Check out the SBC Banks Turbo systems. 427CI @35 PSI=1600hp flynbludream C5 Forced Induction/Nitrous 22 12-16-2003 11:13 PM
30 psi stock tire pressure too high! CJS C5 Tech 21 08-30-2002 01:21 AM
Coolant Change on LT-1 khornet C4 General Discussion 12 09-14-2001 10:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
