Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-18-2006, 12:26 AM   #1
chuck1026
CF Senior Member
Cruise-In II Veteran
chuck1026's Avatar
Default Any pix of 325/30R19's on rear of a C5?
Can anyone post pictures of this setup? I am wondering how far the C6 Z06 tires will stick out of the rear wheel wells of my C5... I plan on going with CCW 19" wheels on the back...
Backup plan is to go with 285's that go on a C6 with Z51.
Thanks!
Chuck
chuck1026 is offline   Reply With Quote
Old 12-19-2006, 07:32 AM   #2
chuck1026
CF Senior Member
chuck1026's Avatar
I am guessing from the responses that 325's are just toooooooo wide for a non-tubbed C5.
Old 12-21-2006, 03:24 AM   #3
99FewteRC5
CF Senior Member
99FewteRC5's Avatar
they'll stick out about a 3/8 of an inch
99FewteRC5 is offline   Reply With Quote
Old 12-21-2006, 07:47 AM   #4
chuck1026
CF Senior Member
chuck1026's Avatar
Quote:
3/8" beyond the wheel well lip, right? I am assuming that would mean the suspension can not compress completely without a tire hitting the rear wheel well... which would be very bad .
Old 12-21-2006, 08:22 AM   #5
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Just tub it............and stuff some 345s in there
http://temp.corvetteforum.net/c5/30s/index15.shtml
Allthrottleandsomebottle is offline   Reply With Quote
Old 12-21-2006, 01:50 PM   #6
E.C.P
CF Senior Member
St. Jude Donor '07
E.C.P's Avatar
They will stick out , but only if you use stock C6 Z06 wheels. Using the Factory Reproduction wheels or Aceslick with the proper off set 58mm front and 65mm rear,and using an 11 inch rim minimum will work .And yes they will NOT rub front or rear, including front lock to lock . Any of the other wheel companies using this off set will also work if you are looking for a more custom looking wheel.keep in mind though that depending if you are planning a big brake upgrade these off sets may not work to clear the calipers.It is always best to contact your custom wheel rep and explain exactlly what you want to do
Hope this clear's things up a bit.
Manny.........
E.C.P is offline   Reply With Quote
Old 12-22-2006, 03:56 PM   #7
chuck1026
CF Senior Member
chuck1026's Avatar
Manny.........
I really think I may play it safe and go with your setup of 275/35/18 and 285/35/19 tires. I spoke with John at CCW and he said, "the 275's will look too big relative to the 285's in the rear".
What do you think he means by that? The sidewall is shorter on the fronts by approx 1/4" and the rears are almost 1/2" wider than the fronts.
What do you think?
Thanks!
Chuck
Old 12-22-2006, 05:42 PM   #8
E.C.P
CF Senior Member
St. Jude Donor '07
E.C.P's Avatar
Chuck if you look at my picture's you can see for yourself .I do have a few more pic's if you are still uncertain . This combination works just great. I think what he mean's is that you loose that look of a drag racer with skinnier tire's up front. I personnally don't like that look for my Vette.Post some pic's when you do get it done. Merry Christmas .
Manny.............
Old 12-22-2006, 07:11 PM   #9
chuck1026
CF Senior Member
chuck1026's Avatar
Hey Manny:
Thanks for the great help. I will certainly post pix once I pull the trigger.
I still hope to go with a 275/325 setup.
Old 12-23-2006, 03:10 PM   #10
chuck1026
CF Senior Member
chuck1026's Avatar
OK... the fun of e-mail has worn off. I think you were right about John's comment... it was with respect to front/rear track, which makes sense. I really think either tire looks great up front.
I called up CCW and spoke with Chip. Those guys are awesome .
I discussed with him the 325/30/19 rear tire option and he said they will fit because the GY SC EMT is a bit narrower than other tires (like a Pilot Sport). I got so excited when he said they would not rub, I forgot to ask if they would stick out beyond the fender wells . Now I need to clear that bit of confusion up.
Other then that, I am hoping to go with the C6 Z06 tires on the CCW's. I think those combined with my Hotchkis sways and some Bilstein sport shocks would make for an awesome handling machine .
Old 12-29-2006, 02:23 AM   #11
spiral04
CF Senior Member
spiral04's Avatar
John and the crew @ CCW
spiral04 is offline   Reply With Quote
Old 12-30-2006, 04:48 PM   #12
chuck1026
CF Senior Member
chuck1026's Avatar
I still am not completely confident that 19x11's with 325/35/19's will tuck in the C5's rear fenders - or at least not stick out past the furthest part of the fender.
I am pretty sure I am going to do it, but I would still like to see some more pix showing fitament.
Also, I was told a 19x11 has a 2" lip whereas a 19x11.5 has a 3" lip. That makes me think the 19x11's would keep the 325's stuffed in better.
Does anyone have a nice shot to show me how well they fit?
Old 12-31-2006, 02:53 AM   #13
DC5
CF Senior Member
DC5's Avatar
Chuck, here is the thread (with pics) from last October when I got my CCWs with the 325s in the rear.
Hope this helps.
BTW, I will be selling these 505As since they won't fit on my C6.
http://forums.corvetteforum.com/show....php?t=1203005
DC5 is offline   Reply With Quote
Old 12-31-2006, 03:31 AM   #14
chuck1026
CF Senior Member
chuck1026's Avatar
Quote:
Hope this helps.
DC5:
Thanx! Still, I have to know... they look like they are not tucked under the wheel wells... is it just the angle of your photo or are they sticking out? If so, how far out are they?
Old 12-31-2006, 11:21 AM   #15
DC5
CF Senior Member
DC5's Avatar
With the 11.5" wheels with correct offsets (inside of tire has only a hair between it and the inner fender well), these wheels/tires will definitely stick out. Sorry the busy pic here.. I took several shots from different angles before I pulled these wheels off my C5 before trading it in.
Again yes, these stick out past the fenders but make for a mean looking rear view, IMO. I really wanted to get extended quarter panels for the rear (3/4" wider) but heard too many issues with fit/finish with what is available for the C5.
I absolutely think the CCW 505s are one of the best looking wheels for the C5. High quality and John & crew at CCW are great to work with. Note: non-coated polished aluminum wheels are a PITA for maintenance. No pain - no gain..
Old 12-31-2006, 12:36 PM   #16
chuck1026
CF Senior Member
chuck1026's Avatar
Nice fleet of vehicles, especially that red car .
I thought they stuck out a tiny bit.
John at CCW did mention the 325's could go on a 19x11. The question is if that will be enough to squeeze those 325's back to the edge of the wheel well. I would surrender 1" of lip (ending up with a 2" lip) to do that.
Old 01-06-2007, 01:24 PM   #17
chuck1026
CF Senior Member
chuck1026's Avatar
Has anyone sucessfully used Vette Magazine's setup on the rear? The squeezed a 325/30/19 on a 19x11" wheel .
Old 01-07-2007, 03:28 PM   #18
chuck1026
CF Senior Member
chuck1026's Avatar
Old 01-10-2007, 11:25 AM   #19
Vince99FRC
CF Senior Member
Vince99FRC's Avatar
Send a message via AIM to Vince99FRC Send a message via MSN to Vince99FRC Send a message via Yahoo to Vince99FRC
You are so motivating.. Hell I bet you could run 9's with my rwhp...
Vince99FRC is offline   Reply With Quote
Old 01-10-2007, 10:25 PM   #20
chuck1026
CF Senior Member
chuck1026's Avatar
I can't believe I am the only person interested in using Vette Maazine's setup. Hasn't anyone done it already? The article was in the June issue last year .
*EDIT* Here is the link to the article... http://www.vetteweb.com/tech/vemp_06...els/index.html
Reload this Page Any pix of 325/30R19's on rear of a C5?
Tags
30r19, 325, 32530r19, c5, corvette, rear
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
