Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-16-2006, 10:24 AM   #1
goatts
CF Senior Member
goatts's Avatar
Default Bon-Aire BA121L Air Compressor
Anyone have one of these. I'm looking for a cheap air compressor to pump up my tires for autocross.
goatts is offline   Reply With Quote
Old 12-19-2006, 12:54 PM   #2
C5 XTC
CF Senior Member
C5 XTC's Avatar
I believe that is a 120V compressor; will work at the site if you have access to power. I'm looking for a good 12V model (car plug in type). Know of any? C5 XTC
C5 XTC is offline   Reply With Quote
Old 12-19-2006, 06:22 PM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
two birds, 1 stone
Conti-Comfort kit
• Braided air hose
• Threaded hose end (more secure than push-on, thumb-lock inflation head)
• 15-foot power cord
• Lighted pressure gauge
• Low-intensity LED supplemental work light
While it isn't intended to make tires sound quieter or ride smoother, Continental Tire's ContiComfortKit is capable of comfortably sealing typical tire punctures making it possible for you to complete the drive home, to work, an important appointment or a tire repair facility. The ContiComfortKit carries Germany's TUV approval and is suitable for use with passenger car tires, including run-flat designs, as long as the vehicle's recommended tire pressure does not exceed 43 psi (3.0 bar) and the tire dimension is within the recommended application range.
Suitable tires are typically fitted on most performance and passenger cars, family minivans and crossover vehicles (vehicles that combine the features of a car with those of a minivan or small on-road sport utility vehicle). The ContiComfortKit can be used year-round in temperatures ranging from -22° to 158°F (-30° to 70°C), and features an illuminated pressure gauge, backlit operating instructions and built-In light to make it easy to use at night.
The ContiComfortKit combines a powerful, high-volume, 12-volt air compressor, integral pressure gauge and a latex liquid tire sealant packaged in a compact, lightweight unit that's easy to store in the vehicle. (Kit is 9.5"W x 7"H x 3.75"D.) The sealant is compatible with direct, valve-mounted tire pressure sensors since the sensors can be washed and adhering residue can be peeled off easily when the tire is repaired.
The ContiComfortKit can also be used as a stand-alone compressor without the sealant activated. When used in this mode, the ContiComfortKit can be used for periodic tire maintenance to compensate for tire pressure losses over time or due to changes in ambient temperature. And in the case of a very slow leak, the ContiComfortKit can restore sufficient pressure without requiring the use of sealant to drive the vehicle to a nearby tire repair facility.
Without even removing the foreign object (such as nails or screws) in the case of a fast leak or a flat tire, activating the ContiComfortKit sealant will inject the liquid latex tire sealant and the compressor will reinflate the tire to comfortably provide a quick and simple temporary repair of the most common tire hazards, such as tread area punctures caused by nails and screws up to approximately 1/4-inch (6mm) in diameter.
A typical passenger car tire that is flat will take less than seven minutes to fill.
Once the sealant is activated and inflation pressure is correctly set and confirmed with the ContiComfortKit's integral air pressure gauge (NOTE: normal pencil, dial and/or digital tire pressure gauge may become contaminated by the sealant and should not be used) after driving a few miles, the temporarily repaired tire is ready to be driven for up to 125 miles (200 km) at speeds up to 50 mph (80 km/h).
So in addition to making routine tire maintenance easier, the ContiComfortKit is the on-board maintenance resource for most cars, family minivans and cross-over vehicles that can inflate a tire with low air pressure, as well as temporarily seal a tread puncture and re-inflate a flat tire.You can verify that the ContiConfortKit is appropriate for the tire size(s) used on your car, family minivan or cross-over vehicle by locating the tire width, aspect ratio and rim diameter branded on the sidewall of your tires in the following table.
The ContiComfortKit is not suitable for any other tire sizes than those listed. Only the sizes shown are acceptable. Use only for passenger car tires listed in the following tables. Do not use if vehicle placard inflation pressure exceeds 43 psi.
Every ContiComfortKit has a "use before" date printed on a seal that is placed adjacent to the instructions on the face of the ContiComfortKit. The "use before" date identifies the latex liquid tire sealant's forty-eight month life span from the time the sealant was bottled. Just before the "use before" date is reached, you should replace the sealant canister with a new one by ordering ContiComfortKit Replacement Parts that includes a new bottle of sealant.
Luke@tirerack is online now   Reply With Quote
Old 01-04-2007, 08:18 PM   #4
C5 XTC
CF Senior Member
C5 XTC's Avatar
Quote:
I just purchased one from Auto Barn. Higheer PSI intended for truck tires but fill up our tires faster. Used one a friend had and liked it. I think it was $42 plus shipping.
C5 XTC
Reload this Page Bon-Aire BA121L Air Compressor
Tags
air, ba121l, bonaire, car, compressor, conti, corvette, inflate, inflation, inflator, kit, passenger, professional, tech, tire, tires, vendors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
