Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-13-2006, 04:33 PM   #1
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
Default Tire Pressure Monitoring Systems
GM Cars
An Update on Tire Pressure Monitoring Systems and Aftermarket Wheels
A direct tire pressure monitoring systems (TPMS) will be standard equipment on every vehicle sold in the U.S. after September, 2007. The criteria for TPMS standardization is that the vehicle must have only four wheels (no dual-wheeled trucks or motorcycles), and weigh less than 10,000 lbs.
GM has used TPMS since the 1987 Corvette hit the streets. They started with the direct strap-style system on the C4 and transitioned to a direct valve sensor TPMS (see TPMS Facts below) on the C5 and C6. Wheels can be swapped with ease, as most GM sensors can be recalibrated with a high-powered magnet available at most hardware stores. Other GM vehicles are equipped with an indirect TPMS that requires several steps and a little bit of straight-line driving to reset it. All GM valve sensors are currently being produced by Schrader, Siemens, or TRW. The Tire Rack carries all three. With the exception of the early C5 Corvette's large sensors, sensor size shouldn’t be a problem with most wheels. Wheel manufacturers are aware of the large sensor issue and are rushing to get most of their wheels TPMS-compatible.
The Tire Rack's fitment specialists have carefully determined which wheels that are currently available will be compatible with the system installed on your vehicle.
If you have any questions about the wheel you're considering, call or post your question for confirmation that it will be compatible with your TPMS.
TPMS Facts
Direct TPMS use a sensor in the wheel/tire to wirelessly relay pressure back to the driver via a display inside the vehicle. Some vehicles have a digital screen that continuously shows all four tire pressures (five if spare has sensor). Others simply flash a "low tire pressure" light on the dash. Additionally, there are two different styles of sensors for a direct system: a valve sensor and a strap/band sensor. Only valve sensors are used on current GM direct system-equipped vehicles. If you bought an aftermarket SmarTire TPMS, its sensors are held on by a strap around the barrel of the wheel.
Indirect systems work in conjunction with the ABS wheel speed sensors that “count” the number of revolutions of each tire. If the right front tire is low (25psi) it will spin faster than the left front tire (35psi). The ABS system will recognize this change and alert the driver with a flashing light and possibly a loud chime. GM's indirect systems do not affect the fitment of aftermarket wheels.
Luke@tirerack is offline   Reply With Quote
Reload this Page Tire Pressure Monitoring Systems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Tire Pressure Sensor 101 for track use jmess C6 Tech/Performance 12 07-01-2005 09:53 PM
Tire sensor malfunction wvst8tprblk C6 Tech/Performance 29 12-19-2004 04:59 PM
I need the tire sensor relearn procedure for 01 c5...sorry if this is a beat topic chimneyguy Wheels & Tires 9 10-14-2004 10:27 AM
*** C5 Goodyear F1 Supercar / F1 GS-D3 Tire Poll *** [PLEASE VOTE!] Tiger Shark C5 Tech 19 07-08-2003 10:38 PM
Watch out for this car on Autotrader.com Vettegirl94 C5 Corvettes for Sale 28 06-04-2003 09:32 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
