Quote:
Originally Posted by BlueThunderousZ06
I'm using my stock C5 Z06 Speedline rims with the 17 front, 18 back and Nitto only makes the NT01 275/17 in a 40 series. If I go with 18s all the way around I could run the 275/40/18 in front and 315/35/18 in back. This would be and ideal set up but I have not found a good deal on some 18 inch rims.
In trying to decide what tire/wheel sizes to use on my C6 Z06 for track use, I am getting a little confused. I decided to calculate the resulting diameter based on different tire/wheel combinations.
Goodyear F1 stock
Front: 275/35-18
Width: 10.827
Height: 3.789
Diameter: 25.579
Revs/Mile: 812
Rear: 325/30-19
Width: 12.795
Height: 3.839
Diameter: 26.677
Revs/Mile: 779
Toyo RA1
Front: 275/35-18
Width: 10.827
Height: 3.789
Diameter: 25.579
Revs/Mile: 812
Rear: 305/35-18
Width: 12.008
Height: 4.203
Diameter: 26.405
Revs/Mile: 790
Rear: 335/30-18
Width: 13.189
Height: 3.957
Diameter: 25.913
Revs/Mile: 803
Nitto NT01
Front: 275/35-18
Width: 10.827
Height: 3.789
Diameter: 25.579
Revs/Mile: 812
Front: 275/40-18
Width: 10.827
Height: 4.331
Diameter: 26.661
Revs/Mile: 790
Rear: 315/30-18
Width: 12.402
Height: 3.720
Diameter: 25.441
Revs/Mile: 819
I checked the validity of my calculations against the Goodyear published diameters of the stock tires of 25.6 front and 26.7 rear, which are both within .025 of my numbers. The tire sizes listed are from official web sites.
The car stock has the rear tire diameter 1.1 taller than the front. Using Nitto tires on 18 wheels the best you can do is the front .138 taller than the rear. The effect is only half the total difference since you only take into account half the diameter, but that still leaves a .619 (5/8) relationship change. The Toyo tire option comes close to the stock relationship, but would it be better to use the wider/shorter tire (335/30) or the narrower/taller tire (305/35)?
Just how important is it to maintain this relationship in tire diameter front to back? If there are other specific tire manufacturers/sizes and wheel sizes to consider, please comment.
And then there is the issue of rim width
