Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-09-2006, 06:53 PM   #1
Doug Harden
CF Senior Member
Doug Harden's Avatar
Default Anyone's chrome wheels look like this?
Is this "to be expected" after only 4-8 months time?
I keep my car washed weekly and have never driven in the snow (it is a Corvette afterall). The only thing that ever been used on them is Zaino.
http://www.hardenmotorsports.com/images/1.jpg
http://www.hardenmotorsports.com/images/2.jpg
http://www.hardenmotorsports.com/images/3a.jpg
http://www.hardenmotorsports.com/images/3b.jpg
http://www.hardenmotorsports.com/images/4.jpg
http://www.hardenmotorsports.com/images/5.jpg
So is this a warranty issue or am I screwed?
Doug Harden is offline   Reply With Quote
Old 08-09-2006, 11:48 PM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
Looks like they didn't do such a good job on the chrome. I would definitely pursue a warranty claim at this point.
MYCoupe is offline   Reply With Quote
Old 08-10-2006, 01:20 AM   #3
Keith N
CF Senior Member
Keith N's Avatar
I would send those same pics to the company where the wheels were purchased. The follow up with a phone call or two. Good luck!
Keith N is offline   Reply With Quote
Old 08-10-2006, 08:23 AM   #4
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Warranty...........poor chrome job for sure. A good Chrome job cost $$$
Every chrome job begins with polishing the part to a fine luster. This helps seal in impurities in castings and prevents the subsequent platings from "dropping into" minute surface imperfections in the material.
Cast wheels particularly must be carefully polished to seal the surface and provide a smooth face for the nickel and chrome plates.
Chroming hardware requires careful preparation as well, especially to keep from losing anything.
Special anodes--which resemble pencil-thick wires and are intended to provide a positive charge near the to-be-plated surface--fit into wheels and other parts to help evenly distribute the electroplating materials.
When placed in the chemical bath, the item to be chromed is subjected to high-voltage, low-current electricity to promote deposition of the plating material from sacrificial anode to the item, which is the cathode.
Chroming's another method of cranking up the surface brightness but it's a totally different process. It is more correctly called a plating process. It's a tricky, difficult method of plating that takes skilled workers to do well. Moreover, there are myriad tricks employed by the high-end chrome shops to make sure the coverage of the chrome on any part is as uniform as possible.
Next comes a plating of copper buffed. This soft metal helps seal in the pores of the metal and provides a smoother surface for the following material to adhere to. If you've seen bad chrome jobs that are full of pits, you can bet that either the polishing or copper-plating job was done hurried. The process is completed with 20 min. nickel and chrome.
Good luck
Allthrottleandsomebottle is online now   Reply With Quote
Old 08-10-2006, 10:38 AM   #5
printmanjackson
CF Senior Member
St. Jude Donor '06-'07-'08-'09
printmanjackson's Avatar
Neal Maners
I have seen aftermarket wheels made in China do that.
Good Luck
printmanjackson is offline   Reply With Quote
Old 08-10-2006, 11:01 AM   #6
Doug Harden
CF Senior Member
Quote:
Good Luck
Funny.....that where these POS were produced...
Old 08-10-2006, 04:44 PM   #7
printmanjackson
CF Senior Member
Neal Maners
Sorry but look at it like this, atleast you did loose that much money.
Old 08-10-2006, 05:53 PM   #8
Doug Harden
CF Senior Member
Gee......I still consider over $1,200.00 enough money to not want to loose.
Old 08-11-2006, 08:44 PM   #9
printmanjackson
CF Senior Member
Neal Maners
lesson learned here, a good set of wheels start at about $2500 and go up. You get what you pay for.
Old 08-13-2006, 07:08 PM   #10
Leo the Lion
CF Senior Member
Cruise-In II Veteran
Leo the Lion's Avatar
Quote:
So what vender did you purchase from?
Leo the Lion is offline   Reply With Quote
Old 08-13-2006, 10:10 PM   #11
arabob
CF Member
My H.r.e.'s With Chrome Centers Started Pealing After 2yrs And They Were 6 Grand So Sometimes You Dont Get What You Pay For, Finally I Got Fed Up,im In The Middle Of Having The M Stripped And Painted To Match The Car Good Luck
arabob is offline   Reply With Quote
Old 08-13-2006, 11:51 PM   #12
saplumr
CF Senior Member
saplumr's Avatar
Looks like road salt.
saplumr is online now   Reply With Quote
Old 08-14-2006, 08:19 AM   #13
Doug Harden
CF Senior Member
Quote:
Don't want to drag the vendor into this just yet...they've been dealing with me, albeit reluctantly.
Old 08-14-2006, 08:26 AM   #14
Doug Harden
CF Senior Member
Quote:
The car has never been driven in the snow... I bought these in July of '05 and the corrosion started before winter set in.
What it is is very thin chrome and the effects of brake dust. I have had a set of polished wheels on another one of my cars for two years now and they show NO signs of corrosion.
Do you think a wheel mfr should 'expect' that the wheels will see some brake dust and that this is a 'normal, reasonable use' of an automotive wheel?
Like most of you, I wash my car at the very least, weekly...but still got this corrosion within 3-4 months of installing these wheels.
There are places on the face of the wheels where the chrome is so thin, it's yellowing....and pitting.
BTW, did you guys know that the "warranty" that most aftermarket wheel mfr's use is not worth the paper it's printed on? They give themselves so many outs that you can't even mount the wheels or they'll void it.
Old 08-14-2006, 08:50 AM   #15
Cruise-In V Veteran
NCM Ambassador
Keep us up to date...........be interesting to know how you make out.
$1200 is enough for a good chrome job
Vendor test time
Good luck
Old 08-14-2006, 09:28 AM   #16
Doug Harden
CF Senior Member
Vendor test time
Good luck
Well after 5 months of emailing back and forth...I "think' we might be close to settling this issue...albeit with me bearing all costs involved, short of the replacement wheel costs....not much of a warranty I say....
I'll be out an additional over $300.00 to have my "warranty" enforced....
Old 08-14-2006, 10:04 AM   #17
Cruise-In V Veteran
NCM Ambassador
If you can put the shipping on a CC........once you get the new wheels.......dispute that maybe
Old 08-14-2006, 01:01 PM   #18
Doug Harden
CF Senior Member
Anyone used either of these wheel sealants?
http://www.autogeek.net/whwaxcarca.html
http://www.autogeek.net/pbws.html
Old 08-14-2006, 04:59 PM   #19
vms4evr
CF Senior Member
vms4evr's Avatar
Might consider using Rejex on the wheels. You can use it on the whole car. It is a sealer as oppsoed to wax.
Not to stir up the pot Doug. But if you got the cheap offshore wheels that sell for $600 chromed I'd say you got what you paid for. But paying $1200 for them I'd say you got burnt. If the vendor isn't willing to completely replace it and using some bogus warranty rules. Then they should be exposed so others don't go down the same path.
Like AT&NB said. Vendor test time.
vms4evr is offline   Reply With Quote
Old 08-14-2006, 05:26 PM   #20
QuikZilver
CF Senior Member
QuikZilver's Avatar
Wow! I have a set of OE Replicas that I picked up from Corvettes of Houston for $699 for the set (2001 factory Z06 size wheels), and they still look perfect! I've had them for over a year now and nothing like that!!! You are taking it better than I would have...and I paid half as much!
QuikZilver is offline   Reply With Quote
Reload this Page Anyone's chrome wheels look like this?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is it just Me? Or does anyone else like Vette Fan C6 Corvette General Discussion 27 05-03-2005 10:26 PM
1991 ZR-1 for $18,000, worth it? Y2KC5NBM C4 General Discussion 34 09-19-2004 07:49 PM
Anyone here ever polished a set of sawblades?? MarkLT1 C4 Tech/Performance 18 02-15-2004 11:15 PM
Longtime lurker's first (looong) post Islander21 C1 & C2 Corvettes 51 12-20-2002 10:11 PM
Anyone "regret" getting black wheels? KMeloney C5 Z06 Discussion 48 11-02-2002 05:49 PM
Extreme "2000 Style" chrome wheels on Z06? Tom Steele C5 Z06 Discussion 23 07-07-2002 02:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
