Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2006, 09:59 AM   #1
96lastc4
CF Member
96lastc4's Avatar
Default help with tire size
Hi
I would like to put 18" factory 2004 wheels on the rear of my 96. What tire size should I use to keep the speedo close? Also is there anything I need to modify?
My current size is the standard 285 40 r17. With the Saw blade wheels.
Thx
96lastc4 is offline   Reply With Quote
Old 08-07-2006, 01:07 PM   #2
aggie88
CF Senior Member
aggie88's Avatar
285 35 18 is right on. I used 275 35 18 on my 95, a bit shorter but not much effect on the speedo.
aggie88 is offline   Reply With Quote
Old 08-07-2006, 03:11 PM   #3
MYCoupe
CF Senior Member
MYCoupe's Avatar
Your current tire is 25.98" in diameter. On the stock C5 rear wheels you are limited to a 275 or 285 section width tire, unless they are Z06, in which case you can go up to a 295 tire.
275/35/18 = 25.58" diameter
285/35/18 = 25.85" diameter
As aggie88 stated the 285 is almost a perfect match. Your speedometer will be off probably by like 0.5 mile at most.
MYCoupe is offline   Reply With Quote
Old 08-10-2006, 09:41 AM   #4
96lastc4
CF Member
96lastc4's Avatar
Hi
thx for the sizes. The local tire Guy thought that 275 40 r18 was also an option what do u think.
Old 08-10-2006, 11:47 AM   #5
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
Originally Posted by 96lastc4
Hi
For a C5 not a C4. That tire has a 26.66" diameter. While it will work, your speedometer error will be greater with that tire. Personally I would stick with a 285/35/18 tire.
Reload this Page help with tire size
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Can I Please Have Some Help With Tire Size For 9.5" Rims? rubyred93 C4 General Discussion 10 01-29-2002 09:29 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
