Quote:
Originally Posted by blkc6z51
Has any body tried to run 17s on the front of a C6? 18s on the rear.
Hi blkc6z51, I am running C-5 18" (stock C-5 rears) on all corners of a C-6 06 vert.
Non Z51
I tried a stock C-5 17" front on to check for clearance and in my opinion it will clear but you have to be carefull with the type of weights you are using, (assuming you are using internal tape weights) due to the clearance between the weights and the rotor. I don't know about other types of wheels but a stock C-5 17" front will not clear the front rotor of a Z51 C-6.
Hope this helps.
Bob
