Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2006, 07:06 PM   #1
Rkreigh
CF Senior Member
Default best viper size shoes
I have a LPE ZR1 with the CCW 18 rims
I need 335/30/18 and 285 or 275/35/18 fronts
I have looked at
Toyo Proxy RA1s
Michelin Pilots
Kumho
BFG Comp RA1s
Nitto NT555
I am currently running the michelin pilot sport cups and like them very much but they only make a 345 or a 315. I ran into a bit of a strange problem on the c4, if the rear and front tire diameter differ too much you code the ABS and ASR at around 50 mph. I know this is the problem as when I switch back to other tire sizes the problem goes away and I was running 335s before.
Like to hear opinions on the best ultra dry handling car. I'm leaning towards the RA1s as I would like to try them. the kumho V700 looks good too but they don't make the 285 front so I'd have to go 305 which honestly might cause some rubbing at full lock.
thanks!!
Rkreigh is offline   Reply With Quote
Old 07-31-2006, 07:32 PM   #2
Rkreigh
CF Senior Member
any thoughts???
Old 08-02-2006, 02:32 AM   #3
stlchevy97
CF Senior Member
stlchevy97's Avatar
this should help you for the rears. i just bought a pair. for my 18x12's
http://forums.corvetteforum.com/show....php?t=1401157
stlchevy97 is offline   Reply With Quote
Old 08-03-2006, 08:10 AM   #4
Rkreigh
CF Senior Member
would the f1 supercar tires have the same tread pattern and work for the front??? looking for a 285/35/18 or a 275 need the tire diameter fairly close to the rears to keep the ABS happy!! thanks.
Old 08-03-2006, 07:38 PM   #5
stlchevy97
CF Senior Member
stlchevy97's Avatar
yes they sure would. thats what i have in my front the f1 supercar 275/40r18's almost identical tread pattern. works for me.
Old 08-03-2006, 10:04 PM   #6
Larry M
CF Member
BFG is supposed to have their KDW2 in 335/30/18 available at the end of August. It also comes in a matching 275/35/18
Larry M is offline   Reply With Quote
Old 08-04-2006, 11:29 PM   #7
stlchevy97
CF Senior Member
stlchevy97's Avatar
there kdw 2 in 335 is already out. its a beautiful tire but expensive. i couldnt find the 275 in kdw2 or thats what i would of gotten. also i just mounted the 18's in the front today its 275x40. stick with the 30 or 35 because mine rubs a little bit when i turn. i dont know what im going to do about that those tires were expensive.
Old 08-05-2006, 01:05 AM   #8
Larry M
CF Member
Quote:
heh? Hardly expensive considering the size and neither are available. 275s will be on the 8th and 335s are listed as backordered
http://www.tirerack.com/tires/Sizes....=33YR8GFTAKDW2
http://www.tirerack.com/tires/Sizes....735YR8GFTAKDW2
Old 08-05-2006, 02:23 PM   #9
Rkreigh
CF Senior Member
the kdw2s look good and are WAY cheaper than the michelin pilot sports
I can use a 285 up front just fine.
I put in a request to see when the 335/30/18s will be available.
these look like they might get the not. the Toyo RA1s aren't available in anything bigger than 275 for up front.
I like the kumho's too but then again, they only have a 305 for up front which is a bit too big (but might work) I have 10.5 rims up front.
gonna keep an eye out, I have a few weeks before I need to pass inspection.
Old 08-06-2006, 12:26 PM   #10
Larry M
CF Member
hahaha
I actually failed inspection for bald tires...been waiting too damn long for these KDWs
I'm going to callBFG this week to see an update from what I heard on Tech where someone says the 315s and 335s will be available by the end of August
If they won't be, then i'll squeeze some 295-35-18s GS-D3s on the 18x11s I plan on getting
Old 08-06-2006, 12:29 PM   #11
Rkreigh
CF Senior Member
anyone run 305/18/35s on a 10.5 rim. I know it should work. but I'm concerned about rubbing. some of my zr1 buddies have run as big as 315 on the front so it could work.
might be the way to go!!
Old 08-06-2006, 12:33 PM   #12
Larry M
CF Member
Not that this helps much, but I know F-Body guys can fit 315s up front without problems....I'm sure a Vette would be the same if not better...Check out the autocross and roadracing section, i'm sure those guys run around with big shoes on all fours
Old 08-09-2006, 11:04 PM   #13
stlchevy97
CF Senior Member
stlchevy97's Avatar
these are the tires i am talking about. just got them mounted today. follow the link i sent you if you need 335 new its a great deal.
Reload this Page best viper size shoes
Tags
1401157, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Do they say that about Ferrari owners... RevDice C6 Corvette General Discussion 18 04-05-2005 12:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
