Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-19-2006, 12:16 PM   #1
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
Support Corvetteforum!
Fozzy_Bear's Avatar
Default Where to buy spacers?
OK, I 'm really supprised that a search didn't dig this up... so I'm sorry if it's a re-re-re-rehash, but...
I've chosen to buy spacers to help my C6 rims fit a bit better on my C5, but I only need a very small size. 1/8 inch would be more than enough.
Where is the best place to buy them, and are there any brands I should look for/ avoid ?
- Thanks
Fozzy_Bear is offline   Reply With Quote
Old 07-20-2006, 11:13 AM   #2
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Allthrottleandsomebottle's Avatar
- Thanks
Look harder grasshopper...........
http://www.ccwheel.com/files/home.php
http://www.dougrippie.com/
http://www.vbandp.com/default.aspx
All good quality.........and you want it with ANY size spacer
Allthrottleandsomebottle is offline   Reply With Quote
Old 07-20-2006, 11:38 AM   #3
Fozzy_Bear
Waka, Waka, Waka!
Fozzy_Bear's Avatar
Quote:
Ah,
I SHOULD have said " I figured a search OF CORVETTEFORUM would have turned up this info, but ..."
I called CCW and got a price that was lower than everyone else, and they were the only ones that said they had spacers less than 1/4" thick. So it was a no-brainer.
I'm only worried that the price is SO much lower than everybody else, that I am missing something. I told Melissa there what I had and what I was trying to do, and she said that she had exactly what I need. But at less than half the posted price of the other web sites, I'll have to wait and see...
__________________
Don't mind me... I'm just the comic-relief, talking bear.
Old 07-20-2006, 12:38 PM   #4
Cruise-In V Veteran
NCM Ambassador
Ah,
They will be fine from CCW.
John and crew put out good stuff and there are more than a few folks that road race with a lot thicker CCW spacers w/o issue.
Just make sure you let me know when your on the road with them.......I don't want to be next to ya
Old 07-20-2006, 01:56 PM   #5
Fozzy_Bear
Waka, Waka, Waka!
Fozzy_Bear's Avatar
...there are more than a few folks that road race with a lot thicker CCW spacers w/o issue. ...
Oh, it's not that I have a problem with bigger spacers. It just that I am afraid that on my particular car, that if I go too much more than 1/8" then I'll start rubbing on the OUTER side of the fenderwell.
After talking with a few clueless vendors around here, I asked Greg Koteski where to get tires mounted and alignment done here on the southside and he pointed me to Rex Harris's shop. (I see why Greg recommends him. He obviously has multiple clues sorted and orgainzed) Rex told me that I would probably need spacers when he put he wheels on (and he was right) and he also told me to make sure to get less than 1/4 inch to avoid going too far the other way.
Now, I admit, the REAL solution to this whole situation is to mini-tub the car. But that will have to wait until we get back from our two week trip to Europe in 45 days.
Old 08-07-2006, 11:49 PM   #6
Black 79
CF Senior Member
Black 79's Avatar
Default Spacers
For an idea of what you can expect: Stock wheels, studs and nuts grab onto 10 threads. With 3/8" (.375") spacers, stock wheels and nuts grab only 2 1/2 threads to hold the wheels on. Not enough! Spacers are OK if you use good quality longer length studs. Racing studs have thread that comes nearly to the end of the stud, so you get even more grab than the stock setup with 1/2" spacers and 1/2" longer studs. Doug Rippie makes spacers that have a hub extention which is usefull to give your wheels stock type hub support.
David.
__________________
For Sale - Black Black Black '00 6 Speed - For Sale http://forums.corvetteforum.com/show....php?t=2140897
(772) 215-7199
Black 79 is offline   Reply With Quote
Old 08-08-2006, 09:40 AM   #7
Fozzy_Bear
Waka, Waka, Waka!
Fozzy_Bear's Avatar
Thanks for the info.
But, in my case, I am using very thin spacers, as my tires were just barely touching at full suspension-travel. IIRC: The man who mounted my tires (who owns a by-appointment-only tire and alignment shop speciallizing in high-performance applications) told me that when I was installing my tires that 3 threads was an absolute minimum and if I had more than 4 full threads of engagement, I should be fine (also keep in mind, this is a DD). When Installing I had just a few degrees shy of 5 threads before I had any contact (finger tight) and once torqued down I was at almost 6.
David,
Thanks for taking the time to post in the thread. Adding safety tips to threads that people might be searching is one of the things that make s this place so great.
It so happens that your info supports the info I had already received, and I myself should be fine. But looking back, I probably should have mentioned this incase anybody searches for spacer info.
Old 08-08-2006, 09:43 AM   #8
Fozzy_Bear
Waka, Waka, Waka!
Fozzy_Bear's Avatar
Also, I rechecked the torque after 1 and 7 days and it was holding at spec. I'll recheck after 30 days and post here if there are any problems.
Old 08-08-2006, 11:55 PM   #9
Black 79
CF Senior Member
Black 79's Avatar
Fozzy:
Thanks for adding the info about the 4 thead min. I was inaware of what the minumum was.
I am currently using spacers on stock (thinspoke) wheels so that they come flush with the outside of the wheelwells instead of having the fenders sticking out past the wheels.
David.
__________________
(772) 215-7199
Old 08-09-2006, 10:15 AM   #10
Fozzy_Bear
Waka, Waka, Waka!
Fozzy_Bear's Avatar
Quote:
David.
Yeah, I can see that in your profile pic now that you mention it. - Looks pretty sweet. Do you have any better pics of it?
What size spacers did you use to get them there? How close are you to rubbing on the outside?
Old 08-09-2006, 11:49 PM   #11
Black 79
CF Senior Member
Black 79's Avatar
I currently have 3/8" spacers and they are just right for the front, but the back needs 5/8" to be just right. I am thinking about the DRM spacers with the center hub lip for the rear.
There have been no rubbing issues on my car, even with 275x40x17s on 9.5 wide rims I ran for a while on the front, but my car is not lowered. I don't know if that would make a difference, but my tires have never rubbed, even when transversing steep driveways at an angle to keep my spoiler from rubbing very much.
__________________
(772) 215-7199
Reload this Page Where to buy spacers?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Do You Use Wheel Spacers? OHSIXX C3 Tech/Performance 30 05-25-2004 07:54 PM
Hoosier 14,5 x 16 drags slicks, anyone tried to fit them?? Austrian Vette C5 Tech 35 12-30-2002 03:28 PM
Where to buy Donovan or Rodeck Aluminum Bare Blocks? Tom454 Engine Mods 18 11-26-2002 07:18 PM
BODY MOUNTS: Replacements? Where & what to get?? 454Big C3 Tech/Performance 15 01-08-2002 12:32 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
