Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-15-2006, 11:36 AM   #1
ToplessTexan
CF Senior Member
Cruise-In II Veteran
ToplessTexan's Avatar
Default Are you running pressure sensors in your Fikses on your C5?
I have a set of FM/5 classics that I'm putting on mine. I have been planning to use the tire pressure sensors. Are there any pros/cons I should be thinking about? Does the sensor fit the rim okay? Cause any balancing issues? Thanks!
ToplessTexan is offline   Reply With Quote
Old 04-17-2006, 09:33 PM   #2
ToplessTexan
CF Senior Member
Old 05-04-2006, 10:09 AM   #3
astig00
CF Senior Member
Send a message via AIM to astig00
I am currently running a set of FIKSE Aro's and no sensors.
astig00 is offline   Reply With Quote
Old 05-04-2006, 12:59 PM   #4
gbsvette
CF Member
gbsvette's Avatar
Send a message via AIM to gbsvette
I've got Fikse Profil 10's but no sensors.
gbsvette is offline   Reply With Quote
Old 05-04-2006, 02:33 PM   #5
triblk6spd
CF Senior Member
Support Corvetteforum!
triblk6spd's Avatar
fm5's here with no sensors.
triblk6spd is offline   Reply With Quote
Old 05-04-2006, 04:47 PM   #6
2000BSME
CF Senior Member
2000BSME's Avatar
what computer problems if any, do you get without sensors. I don't like mine (sensors), because they alarm at just 42psi. I like to run some tires that high ordinarily.
thanks
2000BSME is offline   Reply With Quote
Old 05-12-2006, 02:53 AM   #7
curtbriggs
CF Senior Member
curtbriggs's Avatar
Default FIKSE Aro's
I had to modify the sensors. If I remember correctly, there wasn't enough thread exposed and I had to chuck them in my lath and turn down a lip so they'd protrude more. The sensors work fine.
__________________
1999 C5 Pewter/Silver Coupe,6mn
Mods:Vortec Ttrim, Snow meth injection, AFR 205s, Yella Terras, Comp 224* .580" 112*+2*, PRC Gold w/Ti retainers. Z06 ported Oil Pump, Double Chain timing set. LS6 Intake, Dynotec SuperMaxx headers/no cats, Corsa X and PaceCar mufflers. RPS dual disc clutch, Hurst shifter, DTE Strut Brace & L output shaft, Hotchkis Bars, Z06 Shocks. EBC Yellow pads, SS hoses, Fikse 18"x9.5", 18"x10", Michelin PS2's 265/35 & 315/30, EFI FlashScan, LM-1 controller.
curtbriggs is offline   Reply With Quote
Reload this Page Are you running pressure sensors in your Fikses on your C5?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
