Quote:
Originally Posted by KrisR
Yes, I am getting a pair of 16x8 '98 Camaro wheels sometime in the next few days. I'm researching 16" tires now.....255/50-16 M/T drag radials or Hoosier drag radials, or 26x10.5 or 11.5 ET Streets, or.....well, I don't know yet.
Well, first I got a question for ya. I am assumimg you have your radial tires up front yet.
Have you ever run a bias-ply tire on the back with radials up front before?
If not, be aware of the "loose" feeling you will get as you hit 80+mph going down the track with bias-ply tires on the back (being the 26x 10.50/ 16).
Besides, .....
.......(1) the run out on all 3 tires you are thinking about is the same.
...(2) you will need to buy tubes with the bias-ply tires (added cost of around $125)
....(3) all 3 tires cost about the same (except for the added tubes on the bias-ply)
and ......(4) I have heard great things about the MT ETStreet radials as far as traction.
I would say go with the MT ETStreet radial in the 255-50--16 size. I think you will like them. I would buy them if they had a 27" diameter, as, lke I said before, that is where I think I need to be.
I have heard talk about a 295-50-16 size coming out later this year. I am kinda holding off until then.
I recently had John Boos do some work on my car and need to break it in slowly, so I would be ready for the track until mid summer anyway. I will catch up with you at Rock Falls then and let you make a run with my new tires (and old for that matter) to see if you like them. You will probably have new skins yourself by that time, but we'll get together then anyway.
See ya at the Rock.
