Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-09-2006, 12:28 PM   #1
USAFPILOT
CF Senior Member
USAFPILOT's Avatar
Default C5 Z06 Wheel offset
What is the offset on a C5 Z06 wheel?
I currently have them on my 96 with no issues and am running stock tire sizes. I need new tires and at the end of this month BFGoodrich (i just got off the phone with them) is realeasing the KDW2 in a 315/30/18 which will fit the Z06 Rim. I think if the Z06 rim has the same offset as a Grandsport 11x17 rim I'll be fine.
Regardless, I'll be about 10mm closer to the inner fender well. I've never heard my current tires rub, and wouldn't want any brand new tires to rub.
USAFPILOT is offline   Reply With Quote
Old 02-09-2006, 01:07 PM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
The rear C5 Z06 wheels are 18x10.5" and have a 58mm offset. You might get some light rubbing on the inside with those 315/30. Even though you haven't heard your tires rubbing they could be real close. My driver's side tire rubs ever so slightly on the inside with the 295/35 so you may need small spacers.
__________________
MYCoupe is offline   Reply With Quote
Old 02-09-2006, 01:41 PM   #3
USAFPILOT
CF Senior Member
USAFPILOT's Avatar
i think i heard my drivers side rub once in a right hand turn. is the 58mm offset the same as the gs offset?
i'm too lazy to search threads today
Old 02-09-2006, 10:38 PM   #4
MYCoupe
CF Senior Member
MYCoupe's Avatar
No GS had a 50mm offset. The difference between the two offsets is about 5/16".
Reload this Page C5 Z06 Wheel offset
Tags
c5, c5z06, corvette, offset, rim, wheel, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 wheel backspace/offset needed please 427Z C6 Z06 Discussion 9 09-25-2005 12:12 AM
Z06 Wheel info Trog C4 Tech/Performance 9 04-29-2004 04:20 PM
COMPLETE DIY Mini-Tub, Wheel Offset, and Shock-Travel-Limiter INFO --> 97C5ENVY C5 Tech 32 03-12-2004 11:33 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
