Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-03-2006, 03:49 PM   #1
Eike
CF Senior Member
Eike's Avatar
Send a message via ICQ to Eike Send a message via Skype™ to Eike
Default Pictures wanted: 275 or 285 on 10.5"
Hi,
I'll go for the 2001 Z06 wheels and need new tires (EAGLE F1 GS-D3).
I'm not sure if a 275/35 R18 or a 285/35 R18 would fit the 10.5 wide wheel and does look good, too.
I only found pictures with a 295/35 R18 ...
I'd like to use 275/40 R17 on the front and 275/35 R18 on the rear.
best wishes
Eike
Eike is offline   Reply With Quote
Old 02-03-2006, 06:47 PM   #2
Glennm27
CF Senior Member
St. Jude Contributor
Support Corvetteforum!
Glennm27's Avatar
Location: ...Southampton, PA I love you & miss you Linda
Glenn R Murphy Glennm27
Quote:
Originally Posted by Eike
Hi,
best wishes
Eike
NOt sure why you want to go with such a narrow tire on the rear.
You are obviously going pretty wide up front, so why not go wider in the rear.
If you are using OEM size Z06 wheels then the 18's will be 10.5" wide and will easily take the 295/35 AND they'd be a nice match for the 275/40 fronts.
Now to actually answer your question. The 275/35 and/or the 285/35 tire WILL fit the rear wheel you mention, BUT the 275 may be just a bit too narrow for it.
I do strongly suggest the 295/35 on the rear 18x10.5 Z06 wheel.
And for the record, the OEM Z06 sizes are as follows:
Wheel......................Tire
Front 17x9.5.............265/40x17
Rear 18x10.5.............295/35x18
Glennm27 is offline   Reply With Quote
Old 02-04-2006, 06:09 AM   #3
Eike
CF Senior Member
Eike's Avatar
Hi,
the stock sizes on my '91 are 275/40 R17 on 9.5 wheels for front and rear.
I'd like to have only a little difference between the diameters.
Here in Germany, a 275/35 R18 cost $186 shipped, the 285/35 R18 $272 and I can't get the 295 one.
This is a 275/40 R17 on 9.5" compared to 11" ... that's what it should not look like:
Old 02-04-2006, 11:32 AM   #4
MYCoupe
CF Senior Member
MYCoupe's Avatar
Sounds like you would have been better off with 17x9.5" Z06 wheels all around. I don't see any benefit to using a 275/35/18 tire on those wheels other than price. You would want a 295 section tire for increased traction. I have the stock Z06 17/18 combo with 275/40/17 up front and 295/35/18 out back.
__________________
MYCoupe is offline   Reply With Quote
Old 02-06-2006, 05:41 PM   #5
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Your eye will not differentiate between a 275, a 285, and a 295 tire on the same width rim looking from the side. There is less than one inch difference between the 275 and the 295.
Larry
code5coupe
rocco16 is offline   Reply With Quote
Old 02-07-2006, 08:50 AM   #6
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Allthrottleandsomebottle's Avatar
Here is a 275/35/18 BFG dr on a 10.5 repo..........works fine and drives fine on the road
Just a little short for a full time tire/wheel IMHO
Allthrottleandsomebottle is offline   Reply With Quote
Reload this Page Pictures wanted: 275 or 285 on 10.5"
Tags
0r, 105, 17, 18, 275, 27535r18, 285, 28535, 35, 95, difference, fit, profile, tires, wheel, zr
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
