Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2001, 08:16 PM   #1
tommelton
CF Senior Member
tommelton's Avatar
Default Kumho V700 Rotation
I corded the left front Kumho at Road Atlanta this past weekend. The right front is still in decent shape (or appears to be). I would like to get a tire for the left front and turn the right front around on the rim.
I know it is ok to swap the right side to the left, keeping the same rotation direction, but is it ok to reverse the rotation direction on these tires?
I also know that Kumho does not have a true "rotation" direction anymore as they only make one flavor of the tire (not a rigth and a left). But will the tire be safe reversing the rotation direction after it has been used at speed?
Tom Melton
82 CE
86 Z51 Coupe
tommelton is offline   Reply With Quote
Old 08-10-2001, 12:08 AM   #2
GTB/ZR-1
CF Senior Member
GTB/ZR-1's Avatar
Default Re: Kumho V700 Rotation (tommelton)
You shouldn't have any problems Tom, I've done it myself w/ no issues...
George
GTB/ZR-1 is offline   Reply With Quote
Old 08-13-2001, 11:04 AM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
While mounting and balancing V700 tires on your wheels should be left to a professional with the proper equipment, there are several factors that you should confirm with your installer before he mounts your tires.
The V700 tires features an asymmetric tread designs and "SIDE FACING OUTWARDS" and "SIDE FACING INWARDS" messages are branded on their sidewalls. New tires should always be installed accordingly.
However, while V700 tires continue to be branded with right ("R") or left ("L") side of vehicle markings and rotation arrows which originated with Kuhmo's desire to reduce stress on the tire's tread splices, Kuhmo has since developed tread splices that make following the side of vehicle markings and directional arrows unnecessary. Today, there is only one part number for each size tire and experience has shown that V700 tires can be installed on either side of the car, run at any wheel position, and are not required to be run directionally.
Because a tire mounting lubricant should be used when installing V700's, it is best to mount your tires far ahead of their use in competition to minimize possible tire slippage on the wheel which might affect balance.
Slippage can be confirmed by running a chalk line vertically across the wheel flange onto the tire sidewall. If the line doesn't remain lined up after competition use, some slippage has occured and wheel balance should be
rechecked.
Luke
800-428-8355 ext. 362
Luke@tirerack is offline   Reply With Quote
Reload this Page Kumho V700 Rotation
Tags
kumho, rotation, v700
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need some new tires.... RadPolo96 C4 General Discussion 12 08-14-2002 08:46 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
