Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-25-2006, 09:16 PM   #1
Carl Johansson
CF Senior Member
Default 98 wagon wheels onto an 86?
I have a line on a set of wagon wheels offf a 98 - 17 X 8.5 up front 18 X 9.5 out back. Will they fit an early 86 without using spacers?
Carl Johansson
Carl Johansson is offline   Reply With Quote
Old 01-26-2006, 10:32 PM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
You might have trouble with the rear ones. They might rub on the inside as they will sit in about 1 1/8" more than your current wheels. Even if they don't rub they will look funny being so tucked in. A 1" spacer will solve that problem. You can pick them up on eBay or from www.vbandp.com.
MYCoupe is offline   Reply With Quote
Old 01-30-2006, 03:31 PM   #3
Carl Johansson
CF Senior Member
Quote:
Thanks for the info - but I can't use spacers. The car spends a good deal of time on the track - and many of the sanctioning bodies do not allow spacers!
When you say "sit in" are you saying that the inside edges of the tires will be 1 1/8 inch further in toward the midline of the car - or are you saying that the outside of the tires will be set in an inch from where the originals sat (almost flush with the body panels)
Old 01-30-2006, 05:18 PM   #4
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
Originally Posted by Carl Johansson
...When you say "sit in" are you saying that the inside edges of the tires will be 1 1/8 inch further in toward the midline of the car - or are you saying that the outside of the tires will be set in an inch from where the originals sat (almost flush with the body panels)
Since both wheels are the same width, 17x9.5" and 18x9.5" and the only thing changing is the offset, both scenarios you describe will be true. That is why I caution you that not only will it look funny, but it might actually rub on the inside.
Old 01-31-2006, 07:54 PM   #5
silver84
CF Senior Member
silver84's Avatar
here is another source for adapters
http://www.adaptitusa.com/index.asp?...WPROD&ProdID=2
you should at least think about using
3/4 inch spacers up front,
to keep the same steering geometry
silver84 is offline   Reply With Quote
Old 02-01-2006, 08:48 AM   #6
Carl Johansson
CF Senior Member
I wish I could use adapters - but they are not allowed by the racing organizations that this car frequents! It's a safety issue. There have been several accidents on various tracks caused by the failure of a spacer or an adaptor!
Carl Johansson
Reload this Page 98 wagon wheels onto an 86?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
