Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2006, 03:11 PM   #1
teddyca
CF Senior Member
teddyca's Avatar
Default Lug pattern, offset, what fits C5
I have searched time and time again for the right rim in my price. Wanting to try and stay around $2500 for 19"s is becomming impossible. I have read that the bolt pattern is 5X4.5 and read that this is equal to 5X120mm yet when I call my tire guy he informs me its not. I have found several sets of rims including HP HPR5 and ADR Battle Axe's in 19*8.5 and 19*9.5. This width is equal to our stock rims so they should be fine since I am not concerned with big traction or power at this point. What offset should I consider and if looking in mm what will work. My other choice is to find a set and see if the shop will dry fit them. Thanks for the help.
teddyca is offline   Reply With Quote
Old 01-18-2006, 06:44 PM   #2
OneHalfMex
CF Member
OneHalfMex's Avatar
The bolt circle for the C5 is a 5x4.75. That’s what makes it hard to find wheels made by companies like ADR that will fit. In mm it converts to 5x120.65, which is not the same as 5x120. Some places will tell you that a 5x120 bolt circle will fit however the more reputable places like TireRack say they won’t. I don’t know if I’d want to risk it. It’s only .65mm but it could throw off how your bolts sit against the wheel, which could cause problems. As far as offset goes, your stock wheels are +56mm in the front and +65 in the rear. If your going to get wheels that are factory width you want to try and get the factory offset as well (these large offsets also make it hard to find wheels that will fit). Remember 25.4mm in an inch so if you get rear wheels with a +40 offset but the same wheel width as the factory, they will stick almost an inch (25mm) more than factory… so they will probably stick out past the fenders. Hope this helps!
-Jonas
OneHalfMex is offline   Reply With Quote
Old 01-19-2006, 10:31 AM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
Quote:
-Jonas
good answer
Luke@tirerack is online now   Reply With Quote
Reload this Page Lug pattern, offset, what fits C5
Tags
2006, bolt, c5, corvette, lug, offset, pattern, patterns, rim, rims, size, vette, wheel, wheels, z06, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
