08-14-2001, 09:40 PM
CF Senior Member
Re: Help! Need opinons on 1966 tire and wheel sizes (AlHale)
Assuming correct backspacing, these will work fine. I run 225/60/15 SZ50s on my '64 with no problems. I have 7" wide Western 32 spoke wheels and run disk brakes on front and drums on rear. 16" wheels will better clear the rear spring than my 15" wheels. The 225s will rub on a steering box carrage bolt on a "lock" left turn, but as the bolt has a round head, this causes no damage. 215s will run on front and would clear this bolt. I've seen 235 and 245s used on midyears when the fender lip is shaved.
[Modified by toddalin, 7:02 PM 8/14/2001]
