here's the story
A Tire Rack customer bought a Brembo Gran Turismo Big Brake kit
355mm 2-piece cross drilled rotors
red fixed 4-piston calipers
including all needed mounting hardware and brake lines
he then decided he wanted black calipers so he had them painted using G2 caliper paint
he spent $3149.00 plus shipping.
Then, he found out when he installed the kit his wheels did not clear them.
So, I have the 'used ' kit that has never been driven on that I can sell (with full warranty) for $2234.00 .....
there is only 1 of these .... first come first and only served
make no mistake this is the real deal when it comes to a BBK ....
Ultra High Performance Brembo Gran Turismo Brake System packages were developed to offer race-inspired braking components that are endowed with several significant advantages over a vehicle’s original braking system to provide superior braking time after time. They are for drivers who want to make a statement by substantially improving the looks and performance of their vehicle’s braking system.
While they are available for sports cars, sporty coupes, sedans, light trucks and SUVs, in most cases the Gran Turismo Brake System’s massive aluminum calipers and large diameter brake discs require the use of aftermarket wheels with the necessary brake clearance.
The wheel fitment specialists at The Tire Rack have developed a list of appropriate wheel options per vehicle based on the exact brake kit chosen. This information, designed to make your purchase of Gran Turismo Brake Systems easier and to ensure product compatibility, is available by speaking to any member of our sales team.
Brembo Gran Turismo Systems provide excellent stopping power in everyday traffic, as well as superior high performance street and track driving. They are designed to bolt onto the vehicle’s original suspension, and are fully compatible with the vehicle’s stock brake master cylinder and anti-lock braking system (ABS).
While most Brembo Gran Turismo Brake System packages have been developed specifically to replace the vehicle’s front brakes (due to the high braking demands encountered there), rear brake systems are also offered for selected applications. For vehicles not offering a Gran Turismo System for the rear axle, Brembo Sport brake rotors (slotted or drilled) are available to replace the stock rotors on the rear axle and provide a matched appearance on all four corners of the vehicle.
Gran Turismo Brake Systems packages combine high performance fixed aluminum brake calipers, large diameter 1- or 2-piece vented brake rotors, brake pads, stainless steel braided brake lines and aircraft quality mounting brackets and hardware. (See photo and chart below.) Brake caliper and rotor sizes are selected based on the vehicle’s requirements. In most cases, the aluminum calipers are available in red, sliver or black finishes. Additionally, the rotors feature plain, drilled, slotted, or drilled & slotted disc surfaces depending on the vehicle application and brake system selected. All cross-drilled holes are bi-angle chamfered at the rotor’s outer surfaces to help reduce the cracking caused by repeated, high stress, high temperature brake applications. Gran Turismo brake discs are coated for corrosion resistance to help eliminate rust and to offer a bold, aggressive appearance to enhance the look of the vehicle’s road wheels.
call me if interested
We graciuously allowe dhim to return them
