Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-27-2005, 08:05 AM   #1
Achilleus07
CF Senior Member
Achilleus07's Avatar
Default Caliper Paint
So I just put black grandsport wheels on my Black 96 LT4. Whats the best brand red paint to use for the calipers?
Achilleus07 is offline   Reply With Quote
Old 09-27-2005, 09:55 AM   #2
Luke@tirerack
Platinum Supporting Vendor
The G-2 Manufacturing Brake Caliper PaintSystem Set was developed to show off a vehicle’s brake components through open-spoke style alloy wheels. It can be used to give all of a vehicle’s stock brake calipers the look of expensive, painted, high performance calipers, as well as add color to rear drum brake-equipped vehicles. Easily applied as a brush-on, the PaintSystem Set is engineered for universal application on automotive brake calipers and drums, and will even help protect these vital brake components from potentially harmful oils, chemicals and rust.
The PaintSystem Sets are available in eight high-gloss, wear-resistant colors that can be selected to complement or contrast a vehicle’s primary and/or accent colors. Available colors include: Red, Yellow, Blue, Silver, Gold, Black, Purple, Green and White.
Our experience indicates that a PaintSystem Set provides sufficient materials to paint 4 brake calipers, or 2 brake calipers and 2 brake drums. However vehicles with large brake calipers on the front axle and large brake drums on the rear axle may require two complete PaintSystem Sets to assure adequate coverage.
* Two-part paint system does not require caliper removal
* High-gloss finish
* Colors are fade resistant
* Seals and protects
* Heat-resistant up to 950º F
* Suitable for race cars, too
* Oil and chemical resistant
NOTE: PaintSystem Sets have a shelf life of six months and must be used between 56-70°F (13-21°C) ambient temperatures. Higher temperatures will cause paint to harden faster than normal. Once the paint and reactor are mixed, there are only 4-6 hours working time. After that, paint left in the can will harden and will not be useable.
Do not paint the mating surfaces where the road wheels attach to the brake drums. The wheel’s mounting hub diameter should be measured and masked off on the brake drum prior to painting.
Paint requires 2 hours curing time before reinstalling wheels. Do not use the vehicle for 24 hours to allow the paint to fully harden. Plan application accordingly.
G2 BRAKE Caliper PaintSystem Set Contents:
Detailed Instructions, 1 (14 oz.) aerosol can G2 BRAKE Cleaner Spray, 1 (4 oz.) metal can Brake Caliper Paint, 1 (1 oz.) glass jar PaintSystem Reactor, 1 stir stick, 1 application brush, 1 color decal.
Additional Materials Needed: Masking tape, small wire brush, clean cotton cloth.
Luke@tirerack is offline   Reply With Quote
Reload this Page Caliper Paint
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Brake Caliper Paint C6Harley C6 Corvette General Discussion 18 09-04-2005 09:29 PM
Finally did it (Painted calipers).. lavla C5 General 33 03-03-2005 07:28 AM
Plan to Paint Brake Calipers? GCarrHarris C6 Corvette General Discussion 34 02-22-2005 08:08 AM
What paint to use on calipers?? cmb396 C5 General 30 08-24-2004 06:18 PM
BRAKE CALIPER PAINT Oldguard 7 C3 Tech/Performance 24 03-17-2003 03:24 PM
How good is the Mid America Epoxy Caliper Paint? khornet C4 General Discussion 10 12-16-2002 06:28 PM
Caliper Paint Question... Aceman C5 Tech 12 09-06-2001 03:44 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
