Quote:
Originally Posted by Admiral94
Wow they look nice! I believe that is the setup that I recommended to you. Now you just need to lower the back a little bit. Mine looked too high also after I put on the Z06 wheels. I used longer spring bolts to lower it about 1".
I may want to do that. I did notice that it seemed to be sitting way higher. I think I'll drive it to see if it settles after being driven, then decide if I need to lower it. The taller wheels should have raised it 1/2", but they should also fill the wheelwell by another 1/2". I'd think those would offset, but it does appear to need lowered.
