Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-12-2005, 01:15 AM   #1
PolishDude
CF Senior Member
PolishDude's Avatar
Default why are not all 295s the same?
today i noticed a huge difference with how my stock z06 goodyear 295 looks compared to my friends toyo t1r 295s...the specs are exactly the same but when you look at the two tires from the back mine looks like it has a much bigger footprint then his, and we are both on z06 wheels so wheels have no play in it, his look like 265s compared to my tires, how is this possible?
PolishDude is offline   Reply With Quote
Old 09-12-2005, 02:39 PM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
not all tires are constructed the same even if they are the same size the foot print can vary dramatically
Luke@tirerack is online now   Reply With Quote
Old 09-13-2005, 12:20 AM   #3
anmracing
CF Senior Member
St. Jude Donor '09
anmracing's Avatar
Also keep in mind that the measurements are taken at the widest part of the tire on an "Ideal" rim. Meaning if a mfg says a tire is a 295, it is 295mm at its widest point on a rim that they think it will fit best on (10-12 inch for an example). So any mfg can have a tire measured on their "Ideal" rim but the tread is not measured that way so if you look at a data sheet for tire brands they will have an "Ideal" rim measurement and a tread measurement. Soooo, say mfg "A" states that they have a tire that is a 295, aproximately 12 inches (give or take..) then they will make the tread (Again, as an example) 11.5 inches. Then mfg "B" may have the same 295 width but they want a more squared off look so they would make their tread 12 inches. Basically the tread is not measured the same as the actual width of the tire.
Andrew
anmracing is offline   Reply With Quote
Old 09-13-2005, 09:33 AM   #4
Luke@tirerack
St. Jude Donor '11
section width = widest part of tire
tread width = well, tread width
Old 09-13-2005, 10:08 AM   #5
Wah
CF Senior Member
Wah's Avatar
If the specs are still up, try the section widths of 305/35/18 Hoosier A/R3S03/4 with 315/30/18 Pirelli PZero Corsa. You'll be surprised
Wah is offline   Reply With Quote
Old 10-27-2005, 03:53 AM   #6
skeet
CF Senior Member
My BFG Comp T/A's in 275x40x17 on 9.5 rim measure 10.4 inches wide at the tread and my Bridgestone RE750's same size and same wheel measure 9.5 wide. The T/A's actually look like 315's.
skeet is offline   Reply With Quote
Reload this Page why are not all 295s the same?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
