Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-08-2005, 04:11 AM   #1
1989SixSpeed
Junior Member
1989SixSpeed's Avatar
Default Hunter Road Force Balancing
Has anyone had experience with a shop using the Hunter road force balancer?
I just replaced the front tires on my ZR1 with 2 Sumitomo's (275-40R17). They both balanced with 1/2 ounce of weights or less but the road force number was 15 lbs for one and 19 lbs for the other. The shop people seemed a bit vague on what exactly it meant and said that big tires such as these might be out this much and be considered OK. They said a touring tire on a Taurus or a Caddy might be expected to be within 10 lbs.
Can anyone comment on this?
Thanks,
Doug Gifford
1989SixSpeed is offline   Reply With Quote
Old 09-08-2005, 07:07 AM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
I've had tires balanced in two different shops that have the Hunter balancer. Based on what both shops have told me, a REALLY GOOD passenger car tire will show 6-8 pounds of road force, and 10 lbs. seems to be average. A good truck/SUV tire can be up around 18-20 lbs. of road force.
When I had my run-flats switched over to my CCW wheels 3 years ago, I had them done on a Hunter balancer, but I don't remember the exact roadforce numbers. I doubt, however, that it was as high as your Sumitomos. I replaced the tires on my wife's Jaguar last year with Firestone Firehawks (225/60-16). IIRC, the roadforce numbers were in the 9-12 lb. range.
leadfoot4 is offline   Reply With Quote
Reload this Page Hunter Road Force Balancing
Tags
10lbs, 20, balance, force, hunter, lbs, numbers, road, york
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
HELP! Road Force Balance Didn't jdbxyz C4 Tech/Performance 11 05-12-2005 10:48 PM
Matching tires to wheels with special machine? Cajundude@EnglandGreen C5 Tech 13 03-10-2005 10:54 AM
ZO6 Wheel balancing problems? RacerXq C5 Z06 Discussion 20 06-11-2003 08:51 PM
wheel balancing repo C5 Tech 9 05-17-2002 08:26 PM
Trouble Balancing Firestone Runflats RedVetteMike C5 Tech 14 04-29-2002 02:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
